Results 1 to 15 of 15
Thread: CYA Sock Method
    CYA Sock Method
    I have read on here a few threads about using the "Sock Method" for dissolving CYA into the pool. my question is does the type of "sock" matter? i.e. panty hose vs. cotton sock? does one dissolve faster than the other?
    Thanks for the help
    Eric
    AG 24' round 15k gal
    cartridge filter 125sf
    38,251
    Re: CYA Sock Method
    Should not matter. just something to hold it. I used a T-shirt when i had to add more than a sock would hold.
    JoyfulNoise's Avatar
    May 2015
    13,176
    Re: CYA Sock Method
    Never thought about it. I just use a skimmer sock (I admit, I bought it from a pool supply store on Amazon) and its nothing more than a thick nylon stretchable sock that fits over the skimmer basket. I don't suppose it matters much except for how much CYA you need to add relative to what the "sock" can easily hold.
    Matt
    Jun 2015
    cave creek, az
    1
    Re: CYA Sock Method
    I used pantyhose that cost .33 from walmart and hung them in my skimmer. Hung 4 lbs in there between 2 stockings. Worked great.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CYA Sock Method
    Quote Originally Posted by slimburger1 View Post
    Good deal, and welcome to TFP! Good to have you aboard!
    Essential Links:
    Re: CYA Sock Method
    I thought we had some left over (we used these for skimmer socks) but couldn't find any. just grabbed a pair of full panty hose from the wife and will be cutting one leg (at a time) off to use. thinking about suspending it from PVC pipe in an upside down "L" shape strapped to the return line outside the pool and placing the sock right in the line of the return jet...
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Re: CYA Sock Method
    Quote Originally Posted by pbhound View Post
    I use a stocking as well, but my return jet just pushes it out of the way. I hang it from my ladder, and squeeze it often. The circulation in my pool makes quick work of dissolving it!
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2015
    13,176
    Re: CYA Sock Method
    I have put the full skimmer sock in my skimmer basket before because there's no easy way to secure it to my deck. The only caveat is you have to remove it when the pump is not running because CYA is acidic. As soon as the pump run ended, I transferred it to one of those blue puck floaters. I have good skimmer flow so the sock was almost 80% dissolved by the time I transferred it.
    Matt
    R.J.'s Avatar
    Jul 2012
    Minneapolis
    82
    Re: CYA Sock Method
    I prefer nylons or pantyhose because some of the smaller granules can fall through the holes in a sock.
    18 x 48 Intex Ultra Frame
    2500 gph cartridge filter
    Intex SWG
    Fiddy's Avatar
    Jun 2015
    Hubbard/Ohio
    8
    Re: CYA Sock Method
    Can you add CYA anytime of the day? Does it matter if you break up the total amount - 4lbs, 4lbs, 4lbs - to get my total needed?
    Anthony - 20' X 40' Vinyl IGP, 28,000 Gallons, 1 1/2HP Hayward Super Pump, 3030 Hayward Cartridge Filter, 2 returns, 1 skimmer, bottom drain.
    38,251
    Re: CYA Sock Method
    That is fine.
    Re: CYA Sock Method
    Quote Originally Posted by domct203 View Post
    Dom
    I just did it this weekend with panty hose. what I did was after putting the CYA into the panty hose, I tied a not at the top of the CYA to prevent it from coming up. I had some extra PVC for the by-pass when we clean the filter, and a few 90 degree fittings. took the long (5 foot there about) piece of PVC added a 90 degree fitting on it, added a 2 foot section of PVC onto the other end of the 90 degree fitting, and finished it off with a 90 degree fitting on the end of the 2 foot section that was turned up. tied the rest of the panty hose around the 2 foot section of PVC and placed it in front of the return jet. after about 3 hours on high it was empty. I will have to take a picture next time I do this.
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Re: CYA Sock Method
    Yes, please take some pics. Sounds like a great approach.
    Dom
    Dom - TFP Guide
    Jul 2013
    North Canton, OH
    192
    Re: CYA Sock Method
    I put 2 cups of CYA in a 50 cent knee high (2 pairs for 1.99) nylon and dropped it in the skimmer with the pool at 85°and circulating continuously. 2 days later it was gone.
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    Apr 2013
    Phoenix,AZ
    39
    Re: CYA Sock Method
    The only thing I could add is periodically, every few hours, squeeze the nylon or sock to help dissolve the granules.
    Phoenix, AZ USA 12k gal, IG pebble, Pentair TR-100 sand filter, Jandy/Zodiac ePump series-variable speed, builit 1991 (re-plastered with pebble 2013-new pump 2011), Taylor 2006 test kit with (FAS-DPD) chlorine test w/speedstir, Spa attached
