Thread: My Pool is balanced but still very green.....HELP!
    Jun 2015
    San Jose, Ca
    2
    Angry My Pool is balanced but still very green.....HELP!
    My pool has been green for too long. I had a pool guy replace the energy filter with a gauge, i have brand new cartridges (4) in the filter. The pool has been shocked too many times to count. I clean the cartridges daily or every other day. We used green to clean 6 weeks ago before energy filter was replaced and it was still green after. Help.....
    My pool is 15,000 gallons in ground pool . It has pebble tech and a raised hot tub that flows into the pool. I have a pentair 4 cartridge filter, a whisper flo pump and a Jandy energy filter with a gauge. I have a polaris 360 pool sweep. Jill
    30,403
    Re: My Pool is balanced but still very green.....HELP!
    Welcome to the forum.
    Easy Peasy.
    1. Stay out of the pool store from now on.....you have put in some stuff that has unwanted side effects and that needs to stop.
    2. read "The ABC's of Pool Water Chemistry" up in Pool School. Gain a good understanding of the parameters that really define a balanced pool. Understanding the "ABC's" is the basics for all we teach.
    3. A pic of your pool water would help us.
    4. Be willing to test your water yourself. We want to teach you to manage your own chemistry but it will require a precision kit with you being the CEO of that kit.
    5. Once you can post back some test results for us, we will teach you to SLAM the pool and over a period of days (but not overnight) we can have your pool sparkling.
    Jun 2014
    15,008
    "Ash", I have been in your shoes as well, not too long ago. It all changed with this site and getting my own "proper" test kit. Why? Because we've all learned (from personal experience) you cannot reply on pool store tests, test strips, or simple over-the-counter kits. They don't read Free Chlorine (FC) or Cyanuric Acid (CYA) levels accurately or to the high levels we need. Please see the TF-100 link below.
    As for those pool store miracle products ... well... as you now know, there are none. "Free testing" simply is a way to get you/us in the door to buy their products. I used to clean my "green" filter EVERY day like you until I cracked the code here with TFP. You can too. Now once every 3-4 weeks, and it's just gray dirt residue, not algae. Just read those topics Dave mentioned above (links also in my sig), get that test kit ordered ASAP (priority #1), and you'll be amazed what you can do for your pool.
    Welcome, and let us know if you have any questions. Have a great day.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Not much to add to what the others have said, other than Welcome to the forum!
    With the weather conditions you in CA are experiencing, a drain and refill that the pool store would suggest is most likely out of the question.
    Your water can be saved, by taking control of your pool. Look around, you will find many threads from others dealing with this same situation. We're not going to blow smoke at you, but we WILL help you get your pool back to a pristine, lovable condition.
    Jun 2015
    San Jose, Ca
    2
    My readings were: FAC 4, TAC 4, CH 225, CYA 80, TA 80, PH 7.4 . I HAVE ORDERED A TEST KIT SHOULD BE HERE IN A FEW DAYS. THANKS FOR IMPUT.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Quote Originally Posted by ash3miles View Post
    Welcome to TFP! If only those test results could be trusted. As others have mentioned...your CYA is probably much higher. Unfortunately, our water restrictions present a unique challenge. Once your test kit arrives, give it a test drive and come right back to this post and ask away! You will get some great advice.
    Just to give you some confidence (and after reading Pool School), typically for a pool your size, you should only need to add about 3 cups of bleach a day with an occasional dosing of muriatic acid. That will only be about $6/week in chemicals. Way cheaper (and easier) than the pool store or your daily stop at Starbucks!
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
