Results 1 to 8 of 8
Thread: Stenner install: To tape or not to tape...to trim or not to trim
    May 2015
    Chandler
    107
    I am installing the stenner pump into a Tee fitting. The instructions say to wrap the male end of the injector with 2-3 wraps of plumbing tape. Then there's a pic that says do not use plumbing tape. Do you guys know if it matters? I'm talking about the injector fitting that goes into the return.
    Also, it says to trim the end that will go into the pool plumbing as necessary, called the injection fitting quill. What would constitute necessary? I screwed the injection end into a 1/2" thread on the Tee fitting. So...
    Those of you that have done this could you let me know if this is important or what you did? Thanks so much.
    Matt
    14,000 gallon pool, plaster, Pentair FNS 60 DE, Variable speed pump, Chandler, AZ (Phoenix area)
    Apr 2015
    Tucson/AZ
    90
    Re: Stenner install: To tape or not to tape...to trim or not to trim
    Quote Originally Posted by myers2115 View Post
    Matt
    I drilled a 7/16" hole into a 2" 90 deg and 2" pipe, tapped it with a 1/2" 18-NPT 1/4" 18-NPT, used teflon tape (~3 wraps) and screwed directly into the hole. Did not trim the end. Since the quill is roughly in the middle of the return flow, didn't feel it necessary to trim it.
    Gary
    20,000 gal IG Plaster Irregular Shaped Pool (1987), Hayward SP3400VSP Ecostar Pump, Hayward Pro-Grid 60 SqFt DE Filter, Hayward Pool-Vac Ultra, TF100, Speed Stir, Stenner Pump & 15 Gallon Tank, Oasis Z5, and LA Spas H.E.E.T Model
    May 2015
    Chandler
    107
    Thx Gary. Maybe tapping would be simpler. Would a 1/2" 14-NPT work just as well?
    22,553
    The injection fitting has two threaded fittings on it. One is ¼" 18-NPT and the other is ½" 14-NPT. If you're screwing it into a tee, then the ½" section is probably what you want. I don't think you'll need to trim the quill. That's if you're installing it into a small pipe and it's too long to fit.
    Apr 2015
    Tucson/AZ
    90
    Sent from my VK810 4G using Tapatalk
    Sorry - tap size should have been 1/4" 18-NPT. Will correct.
    Gary
    Jul 2013
    Dallas, TX
    12
    When the instructions state to avoid plumbing tape, they are referring to the threads on the pump where you connect the tube fittings. Don't use tape on the pump, just the the injector.
    17K gallon IG Plaster. 48sqft Hayward DE filter. Stenner Pump
    May 2015
    Chandler
    107
    Thx JP2, that's what I was wondering.
    Mar 2015
    Sugar Land , TX
    424
    I installed mine the exact same way as Gary. No issues!
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
