Results 1 to 9 of 9
Thread: Pristine Blue Hair Staining
    Jun 2015
    Tn
    4
    I am in the same boat with a small new 7,700 gallon pool. I've only used pristine blue twice, but my sons bleach blonde hair is green and its a constant hair battle. I would like to switch to chlorine. I'm getting my water tested again tomorrow, but last week after my last PB dose, I was at .3ppm copper. Do you have any advise on making the switch?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pristine Blue Hair Staining
    Hi triple M! Welcome to TFP,
    I moved your post to a new thread here on its own. You can switch easy. 0.3 is enough to cause staining on plaster, but I don't know what the threshold is for hair staining. Whatever you have, it sounds like enough, and I suggest a drain/refill. Best to leave a foot minimum of water in a liner pool so I wouldn't take it further than that. Drain half and replace then do it again. Or, do it in thirds if you want to be really safe. We shy from anything with Copper because of staining. We are big on testing our own water and maintaining critical parameters with common products like Bleach, but our cornerstone is understanding more than anything else. Take a look at Pool School, and start with the ABCs. You'll need a good test kit, but the know how is all here, and plenty of people will help you along the way.
    Essential Links:
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    To get rid of the green hair, squirt ketchup on his hair,rub it in then shampoo as usual.
    chiefwej
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP!
    Get one of the Recommended Test Kits, I use the TF100 from tftestkits.net.
    Here are some of my fave Pool School articles to get you going
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Jun 2015
    Tn
    4
    I haven't tried the ketchup. I did baking soda and vinegar on the hair. It helped but we are not all blonde again.
    I drained 1/3 and with heavy rain the copper level is .2ppm. What are thoughts on Proteam Metal Magic? Thanks! Marcy
    Middle TN, New pool May 2015, above ground 12'x24', 7700 gallons, vinyl liner, sand filter. Converting from Pristine Blue to Chlorine. We are blondes who now have green hair!
    alexteek's Avatar
    Jun 2015
    Schertz, TX
    17
    When my daughter was little she had white blond hair too and it would turn green from the pool. We used a shampoo and creme rinse called Ultra Swim. You can get it at Walmart. It's about $4. I just bought it recently when I got this pool at Ulta also.
    alexteek
    16x32' 13K, IG Tan Fiberglass, 1HP Superflo Pentair pump, Pentair 150 sq. ft. Cartridge, Polaris 360, Built November, 2014
    Jun 2015
    Tn
    4
    Thanks Alex! I bought some Ultra Swim. It will be part of his post swim routine. In the meantime, I'm switching to Chlorine to avoid this copper nightmare.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Welcome to TFP!!
    As others have suggested, you need your own test kit and do not trust the pool stores. They are probably the same folks who said the Pristine Blue was a great system. Order a TF100. That will give you what you need for a couple of years normal use.
    The only other real option for a test kit is a Taylor K-2006. Be careful comparing prices because the K-2006 comes in sizes, designated by a letter. The basic K-2006 has .75oz bottles. Yo need to get the K-2006-C to get the larger bottles that you want. Even then it is a little short on the reagent & powder for the FAS/DPD test.
    I also have the SpeedStir and Sample Sizer. They speed testing and accuracy.
    Support the site
    Jun 2015
    Tn
    4
    Thank you guys, I just purchased TF100. Yes, i should not have fell for their recommendations. Do you know of a home test kit which checks for metals? I am thinking the pristine blue test kit does because how else would they tell you a top off level?
