Results 1 to 9 of 9
Thread: Pump Problems
    Jun 2015
    White Bear Lake, MN
    6
    Pump Problems
    Hey everyone,
    We just got a Summer Escapes pop up pool from Wal-Mart last week and it's been great. Today I went out to turn on the pump for the night and there is not a steady stream of water going into the pool from the pump. I checked for clogs and there are none. Any advice?
    Summer Escapes 12 ft AG Ring QuickSet Pool, 30 inches deep, 2100 gallons, RX600 Polygroup Cartridge Filter System. Water Testing: hth multi-purpose 6-way test strips
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pump Problems
    Welcome to TFP!
    Have you tried cleaning the filter cartridge?
    Jun 2015
    White Bear Lake, MN
    6
    Re: Pump Problems
    Yes. I just cleaned it yesterday and the pump worked before and after I cleaned it. It wasn't too bad, just a little brown.
    Jun 2015
    White Bear Lake, MN
    6
    Re: Pump Problems
    Quote Originally Posted by JohnT View Post
    Welcome to TFP!
    Yes. I did clean it yesterday before the pump stopped working and it wasn't too dirty. Looked clean today too.
    Jun 2012
    western NY
    1,560
    Re: Pump Problems
    I will ask the obvious...is the pump actually running?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2015
    White Bear Lake, MN
    6
    Re: Pump Problems
    Quote Originally Posted by danpik View Post
    I hear it making noise when I plug it in so yes
    Jun 2014
    15,109
    Re: Pump Problems
    Well, a pool that size with such a straight-forward set-up, you wouldn't think much could go wrong if you are sure:
    - Pump is on (check)
    - Water is getting pulled into the skimmer and/or inlet
    - Tubing is free of obstruction
    - Filter clean (check)
    Perhaps unplug the pump and disconnect the tubing if possible just to make sure something small (i.e. toy or debris) isn't stuck right at the pump's intake where water first goes it? Maybe something inhibiting the pumps impeller to spin and push-out water?
    Just thinking out loud here.
    Jun 2015
    White Bear Lake, MN
    6
    Re: Pump Problems
    Weird... tried again this morning and it's working great. I wonder what it could have been?
    Jun 2014
    15,109
    Re: Pump Problems
    AHhh! Good 'ole timing to the rescue. Maybe it was just a matter of something just big (or small enough) to wedge in a tight spot and needed time to get out. Glad you're back to normal.
