Thread: Replaster - grass clippings a problem?
    Valley Forge, PA
    32
    I am about to have my pool replastered with Diamond Brite. I normally have someone cut my grass for me and some clippings inevitably end up in the pool. Since I can't run my Ray Vac for two weeks, would you recommend that I skip getting the grass cut during the two week brushing/curing period?
    30K gal in ground shotcrete pool with Sunstone Select finish
    Attached raised spa with spillway
    DE filter, 400K btu heater
    Ray-Vac cleaner - replaced with Letro Legend 2
    Use BBB methods
    30,432
    Beachnut,
    That sure makes sense to me. Any additional contaminants in your pool during that period will be troublesome. I would do just as you're thinking.
    Mar 2007
    Coastalish 'down easter'
    4,160
    I would never lightly disagree with Dave, fortunately I don't have to here
    However, turning your 'backyard oasis' into a backyard jungle doesn't quite sit well with me. Any chance you can explain to them the fact that yard clippings don't belong in the pool? If they pointed the mower's discharge away from the pool and worked from the pool out for the first 5 or 6 passes it would minimize the grass entering the pool. You are paying them good money to care for your lawn, they should respect your wishes! Perhaps some grass will still enter the pool, but the skimmers should be able to deal with a small amount of debris. And you won't need to use a machette to get to the pool!! (I've almost gotten in fights with the landscapers who blow all the grass into the pool I've just spent ~ an hour cleaning
    Luv& Luk
    -Ted
    Mar 2007
    Ontario
    211
    Your lawn helper must not own a pool, or they would know what a PITA grass in
    the pool is. What about using a mower with a bagger? At least near the pool. Paying
    someone to shoot clipping in the pool would not sit well with me.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Arizona
    924
    I had to look to see where you lived. Thought perhaps you had the same guy, I use. I have gone over and over with him about this. With mine it's not so much from mowing, it's because one of his helpers uses one of those gosh darn blowers and blows the dust, clippings and leaves all over the place. I'm about ready to fire them and look for another crew. Until then, I make sure my pool pump is running on the day I know they are coming so most of it get's to the skimmer sock before sinking.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Valley Forge, PA
    32
    Thanks for the replies
    I appreciate the replies. I understand the mechanics of doing the mowing as I have cut plenty of grass myself. I have a large yard and even the grass that stays off of the pool deck can blow into the pool after the guys leave. My wife and I both work every weekday and don't get home until about 5:00. Believe it or not, the guy that does the mowing has his own pool!
    Anyway, I have decided that it's not worth the risk with the new finish. I will skip at least one week. At least we don't have much rain in the forecast for the next week, so it won't grow that much.
    Thanks for the advice and enjoy your pools!
    Doug
    Use BBB methods
