Thread: still having poor water pressure into the pool
    Jun 2015
    beverly ma
    4
    I'm still in the slamming stage and I have an air tight system. I can clearly see that there's no air in the sight glass of my pump. When I 1st turn on the the filter, I have GREAT pressure coming out of the jets and it slowly dies down after a couple of hours to hardly anything. I look back into the pump and there appears to be no air and plenty of water going in. I back washed and opened and removed the filter and cleaned it. I hosed the inside of the filter (DE filter by the way) and got my pressure back but only for a couple of hours again. Pressure in the gauge has gone up but the plastic valve knob seems a little worn and I'm replacing it tomorrow. I've read a lot about the pumping system in "pool school" but no real mention as to where I should go next with this " losing pressure". Is it just that I need to back wash more often? My pool has been neglected for 2 yrs by the previous home owners. HELLLLLPPPPP!!!!!
    Thanks
    Gunite Diamond II design. east side 20' x west side 9', north side 32' x south 38' (rough measurements). 4' to 10' depth. DE filter made by Jacuzzi
    Mod Squad pooldv's Avatar
    DFW, TX
    24,506
    Re: still having poor water pressure into the pool
    Sounds to me like your filter is doing a great job of filtering all the stuff out of your pool, mostly algae that you are killing. Backwash and add DE when your pressure rises 20-25% from clean pressure and keep SLaMing, it will get better.
    Just in case you haven't done it already. Get a leaf rake and scoop all the debris out of the pool. That will help your slam go faster and use less chlorine.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    That's expected behavior while you're SLAMming. DE filters work almost too well. Resist the temptation to not reload the DE. You'll just ruin your grids.
