Results 1 to 8 of 8
Thread: Wilbar Int Diamond Star 24' 54" thoughts?
    Jun 2015
    defiance
    2
    hoping to get some feedback before I pull the trigger. Looking at getting this from discountpoolsdirect with their luxury package. Total price without install comes out to just below $4500. Installer said he will charge me $1500.
    specs
    • One-piece Aluminum Wall
    • Weather Resistant Polyester Base Paint plus Clear Krystal Kote on outside of wall - locks out corrosion, discoloration and dirt
    • Liquilock Epoxy Wall Backer on inside of wall to prevent condensation buildup
    • 54" Wall Height
    • 11" extra-wide Resin injected Top Seat (radius)
    • 9" Multi-faceted, patterned, Krystal Kote sealed Steel Uprights
    • Two-Piece injection molded high impact Resin Caps- two tone accent
    • Interlocking Steel Stabilizer bars
    • Heavy Duty Injection molded Resin Bottom Track*
    • Snap-In one-piece Resin Bottom Cuff (no hardware)
    • Resin accent "grill" clips snap into bottom cuffs and top caps
    • Pool wall and frame are gray tones in color
    • Lifetime manufacturers warranty with one-year full warranty
    • Available in Round and Oval Sizes
    • All Diamond Star pools require a minimum of one foot clearance around pool
    • Oval Pools have a Yardmore/Narrow Yard Space Saving Design
    • All prices include shipping
    • Installation not included
    • Made in the USA
    • The luxury pool package includes the following:Diamond Star 24 Round Luxury Pool Packages
      Pool wall, 30 Mil Liner, Widemouth Skimmer
      2HP 2Sp pump with cartridge filter
      Waterway 2hp 2sp Pump and 125sqft Cartridge Filter System
      Maintenance kit
      Telepole
      Automatic pool cleaner
      Pool light
      Solar and winter cover
      Flower fountain
      Automatic chlorinator
      36 Easy Entry Step System
      love to get some feedback before I drop some money on this?
      thanks in advance!
    38,271
    Re: Wilbar Int Diamond Star 24' 54" thoughts?
    Welcome to TFP!!!
    I think a smaller 2-speed pump and a larger filter (like up around 200 sqft) would be better.
    What pool cleaner does it come with?
    Apr 2013
    Argyle, TX
    77
    My 21' cost $850 to install
    That price sounds high on installation.
    Check this place for the pool
    National discount pool supply
    http://www.nationaldiscountpoolsupplies.com/
    The New Yorker is what I got with aluminum wall resin top and bottom rails
    Also known as the Morada by wilbar
    Jun 2015
    defiance
    2
    The Patriot Suction Side Pool Cleaner is economical and an automatic option for cleaning an above ground pool of any size (will not work with soft sided, inflatable or Intex pools)
    • No need for electricity - attaches to existing filtration system
    • Universal Skimmer Fitting allows cleaner to adapt to most pool skimmers
    • Octagon foot pad and Buoyancy Ring keeps the proper angle
    • Provides superior cleaning range - includes 30' hose
    • Easy to install and operate
    • Minimizes pool maintenance time
    • 1 year manufacturers warranty
    Welcome to TFP!!!
    Quote Originally Posted by giltyler View Post
    i thought the install price was a little steep as well. However they say this guy is the best in the area so not sure if this is one of those "you get what you pay for" type of situations. My yard is pretty level. guy came out and surveyed it today. said he will have to take 6" on the back side and 3-4" the rest of the way??
    I have the same size pool and the same filter/pump - had it up and running for a few weeks now and love it. It does an awesome job and my water is crystal clear
    I also paid $1500 for my install. Was supposed to be $1200 but when they got here and I showed him the spot we wanted it, it was off level by 1' so there was digging
    Sharkline 24' round 54" aluminum AG pool. Waterway 2HP 125sq ft. cartridge filter. Using k-2006 test kit.
    PaulfromCT's Avatar
    Sep 2013
    Connecticut
    27
    The pool you are looking at sounds like the Morada. Should be about $3000 unless you got an amazing automatic super cleaner. $850-$1100 was our quoted install price for up to a 1" out of level area. Mine ended up being 18" out of level so I did the install (and digging/excavation). If you require 3-6" of leveling of the site, $1500 sounds reasonable for a professional install. Not only is the leveling a PITA, it was tricky to do the overall install of wall, base, liner for the first time. I am sure it will be easier the next time I need to replace the liner or help a friend install a pool.
    24' X 54" round AGP with Uni-Bead Portofino Liner - 25 Gauge, partially in-ground. Hayward Perflex EC-40 D.E. Filter System 1-HP Power-Flo Pump. Installed Spring 2014.
    Apr 2013
    Argyle, TX
    77
    Wonder what happened?
    21' NEW YORKER II 54" DEEP AGP Private Label MORADA RTR WILBAR Aluminum wall
    Hard Bottom and 1/4" Floor Pad 1/8" Wall Foam Well Water Perma 2500 Unibead liner King Technology Pool Chlorine Feeder HAYWARD Diver Dave cleaner
    Waterway 22″ Sand Filter 1.5 HP Center Discharge Pump Single speed Wide Mouth skimmer
    PaulfromCT's Avatar
    Sep 2013
    Connecticut
    27
    Bueller...Bueller...Bueller....?
    DJ? Any Update?
