Thread: Algae I.D. help and ?'s
    May 2015
    Raleigh
    4
    Hey Y'all , been paying attention to the forums for quite sometime but never needed help , now i need the forums advice . My pool has had quite a rough week .Big pool party saturday into sunday ( it was a good one ) Lots of kids all week and temps above 95 too . I run it for 12 hours at night since i get a discount on the electricity . Noticed Sunday evening the water was clouding up so I tested it and came up with normal #'s except for the fc 1.5 ( usually 3-3.5) and cc which was a little greater than .5 but less than 1.0 (using the 10ml ) So i shocked with 2 lbs of cal hypo and increased the output of the salt cell to 60 and have run the filter nonstop since .
    Todays #'s
    FC= 3.5
    CC= >.5
    PH= 7.5
    TA=100
    CYA=30
    The water looks better but this brown algae showed up on the bottom today IMAG2566.jpgIMAG2565.jpg
    Ready to SLAM or ?
    Thanks in advance ...
    13.5k round a/g vinyl . Sand filter, 1.5 hp . Aquatrol , T-5 cell . k-2006 test kit
    May 2015
    Raleigh
    4
    Re: Algae I.D. help and ?'s
    Started the SLAM process just in case , added 170 oz of 8.25 % bleach ( thanks pool math ) to target 12 ppm
    Readings after adding bleach
    FC= 13.5
    CC= .5
    See what tomorrow brings
    30,426
    You are doing the right thing. visible algae, dead or alive, (that's dead in the pic) is maybe the best indicator of all that a SLAM is needed.
    You have a nice grasp of the chemistry involved and you caught this VERY early so I do not think your SLAM will last very long. Good work using your wits and your test kit to recognize your issue and handle it accordingly. That's TFP Pool management!!
    May 2015
    Raleigh
    4
    #'s From 5:30am
    FC=12
    CC=.5
    Water is crystal clear again , vacuumed up the dead stuff . Then I managed to spill the powder for the test kit ( was in a rush ) I might have enough to test when I get home , hopefully someone stocks it locally .
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Wouldn't bet on someone stocking the FAS-DPD test locally. I would order more powder or the XL Option which are available on this page (TFTestkits.net) or you can order the FAS-DPD refill which contains the powder and both liquid reagents to test FC and CC (TFTestkits.net). You will need the FAS-DPD test to manage your pool on an ongoing basis.
    May 2015
    Raleigh
    4
    Have enough for at least one more test tonight
    Current #'s
    FC =7
    CC=0
    Added bleach . Turns out TFtestkits is in my neck of the woods , placing an order tonight .
