Thread: Air shooting out my jet into the pool
    Anita Kessler's Avatar
    Jun 2015
    Mooresville, NC
    4
    Unhappy Air shooting out my jet into the pool
    It looks like air is shooting out of my jet going into my pool. I think it is air. Anyway, the water going back into the pool from the filter is white with a cloudy look. Why is this happing. I have tried backwashing, rinsing, and opening the air bleeder when I put the filter back in to the filter mode. The water coming out of the jet is cloudy.
    Thank you in advance for the help.
    AFK
    afkessler
    Jun 2015
    kettering
    10
    Re: Air shooting out my jet into the pool
    Sounds like you have a leak and our sucking air somewhere
    Jun 2015
    kettering
    10
    Pool level ok. No gasping from the skimmer
    Jun 2015
    Mooresville, NC
    4
    I did just vac. the pool in the waste mode to keep crude from going through filter sand. The water was a little low and I did hear a sucking noise in the skimmer. Will this clear up on its own or do I need to do something.
    afkessler
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    If you here a "sucking sound" in the skimmer it means your water level is too low. Add enough water to come half way up the skimmer opening. There may be indicator marks on the skimmer face that indicate the proper level.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Jun 2015
    Mooresville, NC
    4
    Thanks to you all for the help. It is that my pool water level was too low. I have the water up and I backwashed and all is well.
    Thanks again,
    AFK
    afkessler
