Results 1 to 13 of 13
Thread: Heater Won't Shut Off
    gfurman's Avatar
    Jun 2015
    Pittsburgh
    10
    I have a Pentair 150M CH MiniMax milivolt heater that won't shut off after its been running for a while. About 4 years old. Any help would be appreciated.heater.jpg
    24 ft round 52" >14,600 Gal > Above Ground > Pentair Optiflo 2-speed 1-hp pump > cartridge / DE filter > Pentair 150M MiniMax CH Milivolt Natural Gas Heater > TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: Heater Won't Shut Off
    Sounds like a bad thermostat. It's going to keep running until it reaches the temperature you set it at, and if it doesn't think it's there, it won't shut off.
    gfurman's Avatar
    Jun 2015
    Pittsburgh
    10
    Thanks for your reply,
    Except the on/off switch won't shut it down either...I have to cut the gas off.
    Richard320's Avatar
    Jan 2010
    19,052
    The schematic is in the manual if you're handy with a DVOM. http://www.pentairpool.com/pdfs/Mini...PowerMaxIG.pdf
    If DVOM is an alien term, you're not handy with one.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    That heater is a lot older than 4 years.
    Sounds like someone bypassed some safety.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    gfurman's Avatar
    Jun 2015
    Pittsburgh
    10
    I bought it new in Sep 2009, so the first time I used it was spring 2010....so five years I guess....
    I'm handy mechanically to a degree and can replace parts....DVOM is indeed alien....some kind of meter?
    Jun 2012
    western NY
    1,562
    DVOM = digital volt ohm meter.
    I was inside one of these last year and it seems there is a small board, if my memory is right, that has all of the connections for the thermostats, on/off switch and the millivolt connections for the gas valve. Maybe something amiss on that. Definitely sounds like there is a short in the wiring somewhere before the thermostats if switching off won't fix it.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    I missed the part about the on/off switch not shutting it down. Sounds like the control board is bad. Like danpik said, it's behind the knobs. I think you can still get this part.
    Paul
    Jun 2012
    western NY
    1,562
    I am thinking this is the part you "may" need...
    Amazon.com : Pentair 471677 Millivolt Electronic Thermostat Replacement MiniMax CH and Plus Pool/Spa Heater : Outdoor Spas : Patio, Lawn Garden
    Checking the circuits with a meter would verify this. I would also check the entire unit for some bad wiring that may have been chewed on by critters.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    First, see if the thermostat select switch is even hooked up. If it is, disconnect it and see if the heater then shuts off. If it does, you either have a bad switch, or bad thermostat(s) or maybe the water is so cold that the temp setting wont go below the current water temp. What is the temp of the water?
    Factory Warranty Station for:
    gfurman's Avatar
    Jun 2015
    Pittsburgh
    10
    The water temp is 88...I have no problem turning it on...
    Thanks for the suggestions...I will get in there tomorrow and take a look at this board and the wiring. Thanks also for the part on Amazon...really appreciate the help fellows...
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Wait, Ok the only way to tun it off is the gas valve? Which valve? The one outside of the heater? or the valve inside with the wires and pilot tube coming out of it. Either way, i think the gas valve may be sticking. This time, try unplugging the wires from the gas valve to get it to shut down. If it remains on, its the gas valve.
    Jun 2012
    western NY
    1,562
    Quote Originally Posted by Pool Clown View Post
    Good thought...A volt meter would also be able to confirm if the power is being cut to the valve when the heat is satisfied.
