Thread: Sand Filter Leaking Sand?
    Jul 2014
    Macomb, MI
    18
    So I have some sand on the bottom of my pool near the return. I vac'ed it and it looks like it is clearly filter sand. There is not a ton, but I am thinking that any is an issue. Is there an easy solution to this or should I be contacting the filter vendor to see if I can replace under warranty?
    14k gal, AG, 1hp waterway, sand, heat pump, 7/16/2014 install
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Sand Filter Leaking Sand?
    If you failed to rinse long enough after backwashing recently, that could account for it.
