Results 1 to 7 of 7
Thread: Ph
    May 2009
    Trenton NJ
    497
    Ph
    Been keeping my ph @7.2 since I did a AA treatment two weeks ago. Is that too low? I was thinking if I went higher the stains would come back ( they came back some but not like before test). Any thoughts?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    38,319
    Re: Ph
    In a fiberglass pool, that pH should be fine, although a little lower than I might want it for comfort.
    May 2009
    Trenton NJ
    497
    Re: Ph
    Maybe I should bump up a little? I mean am I correct to think a higher ph could have adverse effects on metal stains?
    38,319
    Re: Ph
    I think you would have the raise the pH a good bit before it would become a problem.
    May 2009
    Trenton NJ
    497
    Re: Ph
    Ok thanks.....like you said I would feel more comfortable @7.4
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Ph
    Don't get too carried away with needing to keep it at 7.4 though. If it goes to 7.8 and stays there for long periods, don't be in a rush to drop it down right away. Eventually it will hit a happy place for pH and TA and you'll have to add less acid over time. If you obsess about keeping it 7.2, 7.4 your TA may get too low and you'll end up adding baking soda and more pH rise again.
    Isolated Spa - 345 Gallons
    38,319
    Re: Ph
    Joel, there is a metal concern here ... thus wanting to keep the pH lower
