Thread: ZODIAC MX8 stops after about 10 minutes
    Jun 2015
    australia
    1
    I recently bought a new house and it has a 44,000L fibreglass pool. The previous owners decided to take the robot they had and i've purchased a Zodia MX8.
    The pool has a cartridge filter which i cleaned when we moved in, i've also cleaned the basket in the pump.
    The MX8 comes with a speed regulator you attach to the vacuum plate (i've got a poolrite plate). I have had this on all of the settings but i get the same result. The MX8 goes for about 10 minutes or so then slows before stopping completely.
    I looked up the manual online and it says to 'close the main drain'. Not having a pool before i have NO IDEA what i'm looking at! Here are some pics of the equipment my pool has.
    Any advice would be very much appreciated!!!
    Jan 2013
    Long Island, NY
    184
    Re: ZODIAC MX8 stops after about 10 minutes
    I'm sure someone here can help using your pics, most of the experts are spot on with their advice. Although, if it were me, I'd call a pool tech and have him/her come, explain the functions of all the valves & control panel, then label them with a sharpie marker for future reference, would be a worthwhile investment (at least for me).
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    the MX8 also comes with a clip on auto regulator at the cleaner head which will regulate the flow through the cleaner to a setting of 2.5. is this fitted or do you only have the valve regulator in the vac plate? Does the Vac plate already have an adjustment valve (a little cage fitted to vac plate)? if so then you adjust this to regulate the flow and remove the other flow valve.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
