Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Pump electrical hookup
    Jun 2015
    San Antonio/Texas
    9
    I have a 2 speed 2.6hp 230V pump that I can't follow how to hook up to the control panel. I have a blue, black, red and green wire from the panel. I know green is ground but it is confusing where the blue , black and red wire connect to the motor. Please help.
    Clayton
    Clayton
    38,489
    Re: Pump electrical hookup
    Welcome to TFP!!!
    Going to need more info ... like where the wires are coming from?
    Is this new or did you disconnect it for some reason?
    You need to figure out which of the wires is a common LINE and which one is coming off the high speed relay and which one is coming off the low speed relay. Then use the wiring diagram on the motor to know where the connect the 4 wires in the motor.
    Jun 2015
    San Antonio/Texas
    9
    Thanks for the quick reply. This is a new motor with pump. I took the old pump to the store with the wires attached and they took the wire off the old and couldn't remember how they went back on. I reinstalled the motor with pump and wired exactly how I disconnected from the timer box and the motor only ran in low speed no matter how I switched at the timer or moved the switch on the motor. The motor ran at the same speed no matter what position I put the motor switch in. At the timer switch the Blue wire is connected to #2 Load, the Black wire is connected to the "A", and the Red wire is connected to the #4 Load. The Green wire is the Ground. The motor has an "A", L1, and L2 connections, so where do the three different colors connect to on the motor? Also, which connections should the White and Black wires from the motor switch be connected to?
    Clayton
    38,489
    I do not know what #2 Load, A, and #4 Load mean.
    What does the manual for the timer say?
    Motor Switch? You will not have a motor switch if the timer is controlling speed.
    Again, WAY more information required to help ... pictures?
    Jun 2015
    San Antonio/Texas
    9
    I took a picture of the timer switch and can't figure out how to upload to this discussion
    I guess it did it automatically. The conduit on the left goes to the motor. I don't know how to tell what's common or hi or low wires at the timer. So don't worry about connecting the three position switch back on the motor?
    BTW I don't have a manual for the timer.
    Clayton
    38,489
    What timer is that? T101 T104 T106?
    Is it supposed to just turn the pump on and off or switch the speeds?
    I can not figure out what I am looking at.
    Jun 2015
    San Antonio/Texas
    9
    It is an Intermatic 2 speed timer model T106R
    Clayton
    Dec 2009
    Central Massachusetts
    2,690
    Take a picture of the wiring diagram for the motor.
    Also, give us the make amd model for the timer. If we had that, I'm sure there is a manual online somewhere. From the timer picture, it's hard to tell what's the common, high, and low wires.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    38,489
    So you have a separate timer to turn the pump on and off? Or are you wasting a lot of money by running 24/7?
    Dec 2009
    2,690
    Ok, you posted before I did. Let me see if I am Google up a manual.
    38,489
    OK so, knowing that this is a T106 to control speed. I understand the wires now.
    The Black to the pump is the common Line
    The Blue and Red to the pump are the high and low speed wires ... impossible to tell which is which, does not matter though as you can just change the trippers to get the desired speed.
    You will not use the switch on the motor at all if you use this timer to switch speeds.
    Need to look at the motor plate to see where to connect the wires in the pump.
    Jun 2015
    San Antonio/Texas
    9
    Here is a pic of the timer
    Just so I get this right: Black connects to the "A", Blue to the L1 and RED to the L2?
    Clayton
    38,489
    Don't know you did not post a picture of the motor plate, but that does NOT sound correct.
    I think L2 is the common
    L1 is high
    A is low
    Jun 2015
    San Antonio/Texas
    9
    The motor is a Century 2 Speed 2.6HP cat B2983 serial 13713J2 part 7-196444-05 type CXCP fr Y56Y
    PH 1. 230V.
    With the pictures I sent of the timer can you tell me what the Black, Blue, and Red wires are? Which do I connect to the "A" post on the motor, which to the L1 and which to the L2?
    Clayton
    38,489
    I have told you that already. Read my posts.
    L1 is high
    A is low
    Jun 2015
    San Antonio/Texas
    9
    Sorry but I'm not an electrician. Does the "A" on the motor mean common? I just want to make sure before I hook up the Black wire to the A post on the motor.
    What at I understand is L1 is either Blue or Red
    L2 is either Blue or Red
    "A" is Black
    if that is not correct, please tell me which color wire goes to each post "A", L1, L2
    Clayton
    38,489
    What part of
    L2 is the common
    L1 is high
    A is low
    Do you not understand?
    Jun 2015
    San Antonio/Texas
    9
    I can't tell from the pump on the diagram what is the A, L1 and L2 posts are and which color wires goes to each
    Clayton
    38,489
    I am sorry if you cannot read my posts which tell you everything you need to know, then perhaps you should not be messing with the electrical wires.
    BLACK = L2
    RED and BLUE = A and L1 ... no way for me to know which is which
  20. Back To Top    #20
    Jun 2015
    San Antonio/Texas
    9
    OK. As I read it the Black wire goes to L2, Red and Blue go to either "A" and L1? Right?
    Ok. I got it now. Thank you very much for your help and sorry for my confusions!!
    Clayton
