Results 1 to 7 of 7
Thread: Hi, What is this and what is it for? Hayward Skim Master SP1070
    Mar 2015
    PHOENIX
    4
    Talking Hi, What is this and what is it for? Hayward Skim Master SP1070
    I believe this is a Hayward SP1070 Skimmer, but I can't find any online diagram that has this thing in it. It seems to be affixed pretty good-maybe that pin in the top? And can't get it to unscrew....? It doesn't look like any part of a Float Valve...is it?
    Further, we're pretty sure the Main Drain is clogged. The hose is connected to the suction line and we think the other goes to the Main and doesn't seem to be connected to an Equalizer Line-not sure tho...
    Yet, what is this other thing and what is it used for??
    thx
    Jun 2014
    15,027
    Re: Hi, What is this and what is it for? Hayward Skim Master SP1070
    Dalf, sorry you haven't received a reply as of yet. My post/reply might help get it refreshed in the cue so that it gets more visibility today. Hopefully a fellow TFP'er with experience in this particular item will know what it is. Have a great day!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    With the location of the pin, my guess would be that it rotates clockwise to latch something into the open port. Maybe something with a flange that sits down in the depression around the port which the disk locks in place.
    Mar 2015
    PHOENIX
    4
    Thank you Tex!
    Mar 2015
    PHOENIX
    4
    Thx JT!
    Do you think one has to use an Allen/Hex wrench to turn it? I tried by hand-couldn't, but the pin is rusted and not sure it can even be done regardless of method. I'll still try tho I found out the house is a 1977.
    We had to drain the pool via an adapter at this skimmer suction port because we feel that the drain could be clogged. Maybe the point you make is the missing piece of the puzzle.
    Yet, how would one drain the pool? There must be a "T" to the pump..yes? One from the drain and the other from the skimmer into the pump. With the non-suction hole being an Equalizer Line.
    Is this/that how it is done?
    Oh BTW, is it bad to leave a pool drained in the summertime here in AZ/10-20% humidity @ 110 degrees?? Having lived in the Southeast, I am familiar with ground water floating of pools. Here in Phoenix, ground water percolation isn't too much an issue...
    Thank y'all again for being so helpful-I'm scoring points with my girlfriend over this...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Did you figure this one out yet?
    JoyfulNoise's Avatar
    May 2015
    13,179
    Quote Originally Posted by DalF View Post
    Yes, it is not good. What surface type do you have? Plaster, pebbletek, vinyl?
    Typically in AZ you only want to drain and expose plaster/pb-tek when the daytime temps are lower than 85F so as to avoid cracking the plaster surface due to temperature changes. That's usually after October and before April. If you do drain (partially) a pool, it's best to do it overnight and get it filled as quickly as possible. Any exposed plaster in the high heat should be kept wet with a water spray.
    [EDIT]
    You can also go get tarps or painter's plastic sheet and cover the surface. Something opaque would work best. Basically you need to keep the heat of the plaster and get the pool refilled as soon as possible.
    [END EDIT]
    Matt
