Results 1 to 7 of 7
Thread: Leaky valve replacement
    rustystang's Avatar
    Oct 2014
    Tulsa, OK
    6
    I'm new to PVC work, and need some tips on replacing a leaky jandy valve at my pump station. Whats the best strategy for plumbing in a new one? A friend of mine suggested the 4 90 degree elbow trick that I've seen people use to fix underground pipes. Is this my best option?
    Leaky valve:
    18K gal, IG plaster w/ infinity edge, Pump1: Single speed 1hp w/ Triton II Sand Filter, Pump2: Two speed 1hp w/ Triton II Sand Filter, Pump3: Two speed 1hp w/ no filter, AutoPilot Digital SWG w/ RC-42 cell, TF100 test kit
    Jun 2014
    15,152
    Re: Leaky valve replacement
    Just out of curiosity, have you ruled-out simply rebuilding that one? I believe Jandy kits are available at many places and would save you trouble of cutting it out - unless of course you really do want a different type of valve. Just a thought.
    May 2009
    Trenton NJ
    497
    Wow that's a lot of plumbing......to replace that one valve all you need is one coupling. Cut the valve out, and extend with a coupling if needed. So you would need a piece of pipe too. Not much
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    rustystang's Avatar
    Oct 2014
    Tulsa, OK
    6
    Pat, the valve itself is fine, it's the joint between it and the pvc that is leaking.
    Ethany, how would I be able to cram a coupling back in there? I don't think there is enough give in that short section of vertical pipe.
    Sep 2013
    Nashville, TN
    382
    Have you tried putting some PVC glue on the joint while there isn't water pressure on it? My be a bandaid for a while. I also saw a company that sells a pvc sleeve that slips over and gets glued on. Otherwise you may have to remove a couple pieces to make it all fit back together.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Jandy valves are dual-diameter. You can either stick pipe into the valve, or a fitting over the valve. Just saw it off, glue a coupling on using the other diameter, and then a reducer to get it back to the original size.
    May 2009
    Trenton NJ
    497
    Lift up on that 90..... All you need is to raise it a few inches to get that coupling in there. You can enough play
