Results 1 to 7 of 7
Thread: Bromine to saltwater conversion
    Jun 2015
    ofallon/Missouri
    3
    I am new to this website and to owning a pool. I couldn't find anything on here that definitively answers my question nor do I know how to make a signature with my info so here it is. I have a 14000 gallon inground fiberglass bromine pool with a 1 hp pentair superflow pump I believe and a Cristal flow 2 sand filter. I live in a place with a very high water table in fact the previous owner must've drained to much water because one side of my pool is bowing in. I have 2 questions really I guess. The first is how can I convert from bromine to saltwater without draining the pool? the bromine is just to hard to deal with. I can never keep the level up and the water must be shocked all the time. Secondly my pool goes from 3ft to 8ft and has 2 jets on the shallow side with 1 skimmer on the deep end. It has a dedicated suction port on the side. I do we a drain near the bottom of the deep end but apparently it does not work because the other hole in the skimmer has been plugged which a pool company told me there must've been a leak or something. I think this is why my deep end turns bad so quickly because there just isn't enough circulation to turn the water over without that drain. Can this drain be fixed without tearing up all the concrete?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Bromine to saltwater conversion
    Welcome to TFP?
    That's actually the second time this question has been asked today, but you really can't switch from bromine to chlorine without a water exchange. Just adding chlorine to the water reactivates the bromine in the water.
    If water is plentiful & inexpensive in your area you may have to go through several partial exchanges to get the bromine level down far enough for the switch.
    Support the site
    Jun 2015
    ofallon/Missouri
    3
    I've heard so many different answers. Leslie's pool supply told me I could shock it with a lot of shock and burn all the bromine offas well. I don't know which answer is correct
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    Leslie's Pool will tell you to do lots of things to your pool that you don't want to do.
    There is info on how to create your signature here: Pool School - Getting Started
    Jun 2015
    ofallon/Missouri
    3
    Haha I'm beginning to realize that.. thanks for the advice
    Mar 2007
    San Rafael, CA USA
    12,082
    You cannot "shock" bromine to burn it off. Adding any oxidizer to a pool that has used bromine for a while, so likely has a larger bromide bank (i.e. has more sodium bromide salt in it) will simply create a lot of bromine in the water. However, it mostly gets broken down in sunlight back to bromide salt. Only a fairly small amount outgases. You'd have to have extraordinary amounts of aeration over a very long time to try at very high bromine levels to get the bromine out of the pool that way. The best way to remove the bromine/bromide is with water dilution.
    Jun 2014
    Oslo
    120
    Bromine is sensitive to UVB. Covering the pool with a solar blanket will reduce the amount of UVB and the sanitizer bromine level will be more stable. If you want to convert from bromine to chlorine you must replace the water. If the pool is warmer than the city water, than you can create a separation layer that is stable enough. Stop the pool pump. Submerge at the deep end a hose with a weight attached and fill the pool with this hose with fresh water. Drain the excess water from a skimmer. In order to make sure that you have no bromine left in the pool I suggest that you bring up the sanitizer level before draining and continue to drain until the water in the skimmer is cold and no sanitizer is present in the skimmer.
    If your water circulation is deficient I think that converting from bromine to chlorine will not help at all. Areas with poor water flow will not have enough chlorine and the green monster will bite. I would first fix the water circulation and then reconsider to convert to chlorine. Best water flow is achived if the flow is equally divided between all exits in use (main drain, first skimmer, second skimmer, etc.).
    South of France inground rectangular 17k pool - ruber membrane. Sliding dome, black thermal blanket covering 75% of the pool surface. Aqualux 3/4Hp pump, glass media sand filter, Zodillac robot, 110W UV-c lamp, Hayward brominator, Caliente 12kW heat pump.
