Thread: Inground Liner pool leak.
    Jun 2015
    Bear, De
    3
    Hi I have a inground pool 4 years old losing about an 1.5 inches in 24 hours. I have let it drain down and it stops at the 3/4 up the lights, just under where the conduit comes out. I thought it was that so I plugged it back up & its still leaking. Water is far below the skimmer & returns. When it stopped at that level, it stayed for a couple of days without losing any more water, so I thought for sure I found it in the light conduits. No leaks near equipment , no leaks at backwash. Tried to dye test around skimmer wells & nothing I could see there, tried around both steps , thought maybe leaking around them. Went all around pool at that light level & could not find any obvious rips or tears. I do have a main drain, but thought if that was leaking it would have kept leaking below the lights & not have stopped for 2 days. Anybody have any ideas?
    Oct 2011
    Minnesota
    164
    Re: Inground Liner pool leak.
    Sounds like it it is the light conduit. Can you describe what you did when you "plugged it back up". Have you tried to fill the water over the conduit and use food coloring to locate the leak?
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    Jun 2015
    Bear, De
    3
    I drained the pool down a little to be able to work in the light. Pumped both lights with 100 % silicone, then as an extra measure put some Duct Seal over it. Waited 24 hours & filled up pool. I have tried the food coloring in both lights & could not see anything that would indicate a leak. Someone told me to plug the main drains & see what happens. I just thought it would have kept leaking down past the lights if it was the main drains, but I'm about to try anything at this point..
    I meant to say both light conduits...
    Oct 2011
    Minnesota
    164
    Sounds like you sealed the lights pretty well. If your main drain has a leak plugging would be a good way to check. Odd that it would be at the same height as the light fixture but certainly possible. Have you tried pressure checking any of the lines?
    Jun 2015
    Bear, De
    3
    No I did not, figured that the water went well below skimmer & returns. I think I will try plugging the main drain & see what happens.
