Thread: Using bleach vs tabs - raises ph?
    Jun 2012
    NJ
    40
    I switched to bleach a few years ago and have realized that our ph is higher these days and i have needed to use muriatic acid to lower it. Previously it has stayed low all season and never really caused a problem.
    Is that a result of switching to bleach? Does it affect the ph differently from the tabs?
    Also noticed we have gotten little spots of yellow algae in the corner of the stairs last season and this season where we never had it before. It hasn't been all over just in a few shady spots. Is this maybe because the ph is running higher than it had been the years before?
    NJ
    35,000 gallons, DE filter, IG plaster
    TF-100
    Aug 2014
    Seminole, FL
    92
    Re: Using bleach vs tabs - raises ph?
    There should be a net zero change in pH from using bleach, whereas pucks will lower pH (which I assume you were using). Most plaster pools seem to naturally rise, albeit slowly.
    Sound like your FC is a little low. Post a full set of results so we can see what is going on. Poor circulation in those troublesome areas won't help either.
    Built 1980, 19' x 30' almost rectangular, screened 15,000 gal, plaster, Hayward DE 3620 filter (currently using cellulose), Emerson 1081 1HP pump, AquaCal Heatwave SuperQuiet SQ110R heater, Zodiac T5 Cleaner, Taylor K-2006 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: the algae spots-Have you been brushing less this year than in previous years?
    Jun 2012
    NJ
    40
    Quote Originally Posted by mikech View Post
    Ok I remember when we put it in they said it does naturally rise so must have been the pucks keeping it in line those first few years. I'll just keep a better eye on it going forward. Thanks!
    NJ
    TF-100
    Mar 2007
    San Rafael, CA USA
    12,082
    The Trichlor pucks are acidic so lower both pH and TA. If you didn't have to add any chemicals for either pH or TA adjustment, then you must have had plaster curing or some other source to counter the pH and TA drop. If the TA slowly dropped so you added baking soda on occasion to raise it, then that means the pH was balanced from carbon dioxide outgassing so you probably had the TA higher (in the 100-120 ppm range or higher).
    With the bleach, it's close to pH neutral. There's a small amount of excess lye in it but most pH rise in pools using bleach or chlorinating liquid (or Cal-Hypo or lithium hypochlorite) comes from carbon dioxide outgassing and that can be minimized by having a lower TA target (usually not higher than 80 ppm) and a higher pH target (around 7.7 or so).
