Well, I finally got my water all balanced, thanks to you fine folks!
Now it's time to address some issues that, well, I didn't think were issues. Joining TFP has me re-examining everything about my pool.
Let me get to the situation:
I have two (2) Baker Hydro Skimmers in my pool. One in the shallow end, one in the deep end. Since I moved into this house, neither has had a complete skimmer weir (i.e., both are broken pretty much in half). Does anyone know where I could locate a reasonably-priced weir for these skimmers? It seems Baker uses a specific design (hydrofoil?).
I also have two (2) of the Hydro-Control Plates. I have only been using those when I vacuum the pool. One in the shallow end, stopped up, then the one in the deep end with the vacuum hose, inserted in the correct position (it took me a summer of having precious little suction before I realized there is a "Normal Use" and "Vacuum" position for the Control Plates). Baker Hydro's website seems to suggest these Control Plates should be used all the time with the skimmers. Is that what I should be doing?
