Results 1 to 7 of 7
Thread: How to reduce TA from 150 to 80 quickly?
    Feb 2014
    Jersey side of Philadelphia
    93
    Going forward, I will be using my own pool testing equipment because my chemistry is screwed up relying upon the pool store test results.
    My TA is 150 (though the pool store said it was 109). This increase is attributable to adding Borax (I think). I want to swim right now and my PH is 7.5. Any thoughts on a quick fix?
    24,500 Gallon (640 SF) Inground Gunite Salt Water Pool w/ Diamond Brite Midnight Blue Plaster. Pentair IC 40 Chlorine Generating System. Hayward 60 DE Filter. Jandy Aqualink Remote System. Polaris 360 Automatic Pool Cleaner. 50 SF Spa with waterfall feature
    Hayward 440,000 BTU Heater. Two Colorlogic LED pool lights.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: How to reduce TA from 150 to 80 quickly?
    What are the rest of your levels?
    FC
    CC
    CYA
    Ph 7.5
    TA 150
    How did you get the two numbers your have?
    We can get you in that pool! CANNON ball!
    Kim
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You can swim, no worries! If you need the TA down, it will go down with time and effort. Focus on pH for now, and enjoy your pool.
    Essential Links:
    38,301
    You should swim if your TA was 500ppm without worries. TA is one of the least important parameters in keeping the pool clean and safe.
    Your pH is fine, but what is your FC and CYA? That determines if the pool is safe.
    Feb 2014
    93
    FC 4.0
    CC .2
    CYA 60 to 70
    Ph 7.5
    TA 150
    I got them from a cheaper pool testing kit that I grabbed from A&S retail store while I wait for the taylor 2006 to arrive.
    Thanks!
    38,301
    With a supposed CYA of 70ppm, you need to keep the FC above 5ppm at all times to keep the pool clear and safe.
    See the FC/CYA Chart.
    Oh, unless you are running the SWG in your signature, then you need to keep the FC above 3ppm at all times.
    Please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you.
    Feb 2014
    93
    Thank you for all of your help!
