Results 1 to 11 of 11
Thread: When to Add Gentle Spa
    Mar 2015
    Moncks Corner
    18
    Going to do my first water change on our Bromine sanitized hot tub - it's been staying nice and clear using MPS and the occasional Chlorine hit but figure it's due.
    So, I printed out the sticky on the setup to do it right (no Bromide bank to start on the first fill). I plan to add Gentle Spa on this go 'round and I was wondering when to add it? I'm guessing once I have everything balanced(?) but I'm not sure. I'm figuring this order:
    1) Bromide Bank and chlorine to get the bromine to proper level
    2) TA, then PH, then CH
    3) Gentle Spa to "lock" things in
    Thanks for any correction to my plan.....
    Jacuzzi J-325 with ClearRay, outdoors, Bromine
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: When to Add Gentle Spa
    Check out this sticky, it references adding Gentle Spa/borates. I would add it last.
    How do I use Chlorine in my Spa (or pool)?
    I use chlorine and borates in my tub and the borates make the water a little nicer. I don't know why they do not recommend adding borates on the how to use bromine in your spa sticky.
    Mar 2007
    San Rafael, CA USA
    12,082
    Gentle Spa is apparently not very pH balanced so will raise the pH quite a bit and need acid to bring it down (though not as much as if you used Borax instead). If you want to add something that is closer to pH neutral and is probably less expensive as well, consider using boric acid from DudaDiesel or The Chemistry Store.
    DFW, TX
    24,485
    That is interesting, the how to chlorinate your spa sticky says: The easiest way to add Borates to your tub is to get a product called Gentle Spa. It is pH balanced, so there is no need to add acid to counter balance it.*
    Maybe we need to change it?
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, it should be changed. That's leftover from the original writeup from Nitro. Originally Gentle Spa was more pH balanced, possibly being more boric acid, but at some point it changed and we found better less expensie sources for boric acid.
    Mar 2015
    Moncks Corner
    18
    OK, well, I have Gentle Spa on the way already - so maybe I add it first and then adjust the PH?
    Mar 2007
    San Rafael, CA USA
    12,082
    I'd add part of it, not all at once, then check the pH and adjust, etc.
    Mar 2015
    Moncks Corner
    18
    Makes sense - thanks!
    Mar 2015
    Moncks Corner
    18
    OK, did the water change out today. After filling I added the Bromide bank and tossed in 3.5 oz of 8.25%C. Added half of the Gentle spa and tested pH at 8. Lowered it per the Taylor guide targeting 7.6. Added the rest of the chemicals and the other half of Gentle Spa. Tested the pH again and again had to lower it. Anyway I end up with the following:
    Br @ 5ppm
    pH @ 7.4
    TA @ 90
    CH @ 160
    I'm pretty pleased with how this went and anxious to see how things go with the Gentle Spa treatment.
    Thanks for all the advice - this site is great!
    Mar 2015
    Moncks Corner
    18
    Br @ 5ppm
    pH @ 7.4
    TA @ 90
    CH @ 160
    DFW, TX
    24,485
    Alright! Here's to good hot tubbin!
