Results 1 to 18 of 18
Thread: Does this sound off to you?
    Jun 2015
    Dallas. TX
    59
    We met with a PB and during the discussions, my husband (who is a project manager and has experience building multifamily properties with pools in Texas) asked about whether the PB puts crushed rock under the gunite to help mitigate movement, he looked at us like we were crazy and said he wasn't sure if they could do that but would have to check. He then said "well that's usually only done if you have an engineer come out and say that it needs it" and that engineers are paid to say stuff like that, it basically that it keeps them in business!
    Wouldn't that be standard (not cost wise, but building wise)?
    Shouldn't that be done always?
    I don't want to completely dismiss a PB due to a weirdo sales guy, but he clearly seemed like he was new and hardly knew more than us about construction...
    No pool yet...will update once we sign the dotted line and begin construction :)
    38,301
    Re: Does this sound off to you?
    I am not sure I have ever seen a pool build on the forum that had crusher put below the gunite. Usually just the rebar inside the dirt hole.
    You have to realize the guy is a salesman ... he likely know very little about the actual pol build and certainly knows even less about how to chemically maintain them in the future.
    Jun 2014
    15,159
    I've only seen references of crushed, washed gravel used for fiberglass pools, but even then not in all cases. My research indicated its use (gravel) depended upon the soil condition and its susceptibility to shift and/or deteriorate over time due to climate changes (drought, saturation, etc). Certainly sounds as if that salesman could have handled the question better and more professionally. As the buyer, those are the kind of situations that make the hair stand-up on the back of your neck.
    Jun 2015
    Dallas. TX
    59
    Quote Originally Posted by Texas Splash View Post
    Perhaps we are being a bit too expectant...at least I can breathe a sigh of relief knowing that its not that abnormal not to have "crusher". At first, naturally, I panicked!
    Jun 2014
    15,159
    That's okay. You have every right to panic. It's a huge investment, even in the most modest of pools. After the pool is done and you're sipping drinks pool-side, then you can relax - until the pool payment comes in.
    Feel free to post questions any time something just doesn't seem right. That's what TFP is here for. I wish I would have done that here before my pool was installed.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    I thought it was a great question! You guys are far ahead of where I was at that point!!!
    I think I have seen one or two gunite pools with crushed rock in the bottom, but I can't remember which thread. I wondered when I saw them if I should have had that. But most gunite pools I've seen do not.
    Now along those lines, what my rebar crew did which I see on other gunite pools is the placement of small brick pieces wedged under rebar intersections on the pool floor to keep the rebar in position before they shoot the gunite. Maybe that does some of what the crushed rock is for - just guessing.....
    Congratulations on your new pool! With your husband's experience, you guys are in great shape!!!! I can't wait to see your plans and pictures of your build!!! Take care. Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    currentking's Avatar
    Jun 2015
    Palm Bay Florida
    91
    Is this what you are referencing?
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Our PB also did crusher under the shotcrete. Maybe it's a Florida \ Texas thing, given the propensity for the ground to shift in our states. If your husband feels strongly, it should be easy to arrange with your PB.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    38,301
    I would not think a "dusting" of stone like that would do much for structural integrity.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    One thing to keep in mind is different areas have different soil conditions, in the case of Dallas I suspect there are probably half a dozen very different types of soil conditions in the greater DFW area, ranging from fairly soft plains soils that are easy to dig, to heavy rock baring soils that you would almost need a pick axe to break, to vast amounts of red clay soil just below the surface.
    ps see Geology of the Dallas–Fort Worth Metroplex - Wikipedia, the free encyclopedia
    Jun 2015
    Dallas. TX
    59
    Quote Originally Posted by SuzfromTexas View Post
    Thanks Suz!
    Quote Originally Posted by currentking View Post
    Yes!
    Quote Originally Posted by Isaac-1 View Post
    Thanks for that link!
    IDK, may do it just to be safe if it's not too much extra $$!
    Quote Originally Posted by txnole View Post
    Yea, I'm okay with the sales guys lack of knowledge if in the end we still have that as an option. What would turn me off completely is if he said just flat out no. At least he said he would look into it.
    Feb 2015
    Leesburg, Va
    164
    We had three dump trucks of stone in ours. We hit fill dirt in our shallow end. I'm very confident ours is not moving.
    Pool build spring/summer 2015. IG. 750 sq ft pool. 40 sq.ft spa. 18ft x 42ft rectangle, 31,000 gallons, SWG, DE Pentair model, 2 boosters variable speed model, heater master temp Pentair, Quartz finish Aegean Green, CoverStar Automated Pool Cover, Kreepy Krawley Platinum, TF100,SpeedStir My Build in Progress
    Apr 2015
    Camarillo, CA
    39
    It all depends on the soil conditions under the pool. We had to have a soil engineer come out and $ay our soil under the pool was OK. If there was an issue and a layer of crushed rock would fix it, then we would have been required to do that. The issue is that the PB is only working off the pools built in your area. If you want to know for sure (or at least another opinion) you would have to hire a soil engineer with experience of pool requirements. The amazing thing to me is a 20,000 gallon pool has like 167,000 pounds of water in it! 83 tons of water! Wow!
    April 1, 2015 first fill of infinity edge of about 15,000 gallons. Aqua Blue Pebble Sheen, iAquaLink, Jandy 2 HP variable filter pump, Jandy 2.5 HP single speed feature pump, Jandy CL580 cartridge filter, Jandy heat pump, Jandy propane heater, spa of unknown size, 3 LEDs in pool, 2 LEDs in surge pond and 1 LED in spa, Eclipse EC-10 Del Ozone oxidizer and 4 Jandy laminars with Jandy CS100 filter built by California Pools in 2015.
    Dec 2007
    Barrington, IL
    6
    I'm in IL where our soil is all clay and the pool builder used crushed rock under the gunite.
    26,000 gal IG freeform gunite pool, pebble sheen, Jandy VS PlusHP pump, Jandy AquaPure PLC1400 SWG, Jandy CL460 cartridge filter, Jandy Hi-E2 heater, AquaLink PDA, Polaris 280, well water auto fill, completed 6/2015, Taylor K-2006
    Mar 2015
    West Palm Beach, FL
    56
    We also had crushed rock dumped prior to shotcrete on our pool. We are located in West Palm Beach, FL area.
    [IMG]Untitled by natvtxn27, on Flickr[/IMG]
    Dig started 5/6/2015!! 17x37 pool. 6x8 Ledgestone spa with 6 jets. Sunshelf w/ 2 illuminated bubblers. Pentair Intelliflo VS pump. Silencer 1hp spa blower. Pentair Ultratemp heat pump. 3 Globrite LED lights in pool, 1 in spa. Travertine marble deck. Easytouch 8 automation. IC-40 SWG.
    Jun 2015
    Dallas. TX
    59
    Thanks everyone!!
    Is anyone in Dallas that could possibly chime in? Since soil varies so differently by location.
    Quote Originally Posted by Novcruisin View Post
    Thanks everyone!!
    We are in North Texas/Dallas. Prosper, Texas.
    We did have the crushed rock put in prior to gunite. We built with Claffey Pools and they touted this as an included upgrade to account for soil movement that you would pay for with other builders. I'm sure we paid for it, just not in a separate line item!
    We love Claffey, by the way.
    40K Gallon gunite chlorine diving pool with spa, Blue Granite finish
    Jandy Watercolors LED lights (2 pool, 1 spa)
    Jandy equipment with RS8 controller
    Borates added in the form of Borax and Acid.
    Prosper Texas
    Jun 2015
    Dallas. TX
    59
    Quote Originally Posted by slappie View Post
    Thanks slappie! I checked them out, and they look like a good prospective builder...but their website shows they don't service my area BOOO!! I still sent them a request for a quote asking if they might reconsider servicing my area, but I won't hold my breath! Most PB are so busy right now I can hardly get them to come out if they DO service my area. Thanks again for the recommendation though
