Results 1 to 8 of 8
Thread: Oversized pump - is this a major problem?
    Jun 2015
    johnston ri
    4
    Hello,
    When I purchased my home many years ago it came with a 24 foot, 4 foot deep above ground pool. It had a jacuzzi filter/pump combo. When the pump died, I was sold a 1.5 HP Hayward pump rated at 70 GPM, and I kept the filter. Many years went by without issue, then the screws on the jacuzzi filter snapped, so I just purchased a Hayward replacement, keeping the 1.5 hp pump.
    Now that I am looking into it more, I see the filter says 35 GPM is recommended, so my 70 GPM pump is too much. (and apparently has been too much for years, but again, no issues)
    I have searched a lot, but cannot find a definitive answer - is this a MAJOR problem? I see that it may not be efficient in cleaning, and I may be paying too much to run it, but is my new filter in danger? Should I run to downgrade the pump?
    Thank you!
    30,415
    Re: Oversized pump - is this a major problem?
    Welcome to the forum.
    I cannot figure out what type of filter you have?
    38,274
    Welcome to TFP!!!
    Please add your pool details to your signature as described HERE as it will help us help you.
    Pumps do not typically move near the amount of water that the spec states for optimal no head loss conditions.
    Jun 2015
    johnston ri
    4
    Thank you for the welcomes - I have a sand filter that has 150 lbs of new sand in it.
    AG 24" round, 4" deep
    Pump - Hayward Power Flo LX 1.5 HP
    Filter - Hayward Pro Series S180T
    38,274
    Can you add what make/model of pump you have? Hayward probably makes 15+ different 1.5HP pumps.
    In any case, a 21" sand filter should not have a problem with a 1.5HP pump ... 35GPM seems a little low for a filter that size. That could be a commercial pool use rate where residential can run a good bit higher.
    Jun 2015
    johnston ri
    4
    Sure thing, thanks
    Pump - Power Flo LX SP1515-Z-1-BC
    Filter - Pro Series S180T - which I now see is 18"...I am positive the "pool guy" said we'd upgrade to 21...
    38,274
    A 21" filter would be more in line with the size I would recommend, although with your shorter season, the 18" should be adequate.
    Put that pump info in your Sig ... well just the Power Flo LX part is enough.
    Your setup should be fine.
    Jun 2015
    johnston ri
    4
    Good news. Thanks for your time
