Results 1 to 7 of 7
Thread: Clorox Bleach
    Nov 2013
    North-Dallas Texas
    18
    Clorox Bleach
    Being in Texas, I'm having a tough time finding liquid bleach.
    Is Clorox an acceptable alternative to the shock granules bought at Leslies pool store?
    Also, using the shock packs from Leslies, does this increase the CYA levels?
    Thank you for your time and guidance.
    15K Gallons IG Plaster Pool 7-9 hours of sun, Pentair WF-28 2HP pump with Cartridge Filter with Pentair heater
    Polaris 280 cleaner
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Clorox Bleach
    Being in Texas, I'm having a tough time finding liquid bleach. Every WalMart has it in the laundry section. GreatValu is their store brand and least expensive
    Is Clorox an acceptable alternative to the shock granules bought at Leslies pool store? Liquid chlorine is not only acceptable, but preferred
    Also, using the shock packs from Leslies, does this increase the CYA levels? They are going to either raise the CYA or Calcium levels depending on the specific product
    I would look for a HASA Dealer in your area for pool chlorine which will most probably be even less expensive
    Support the site
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Clorox Bleach
    Clorox is just fine. Great Value brand from WalMart is fine. Any type of bleach is fine as long as it's regular, unscented bleach. Do not use splashless or outdoor bleach. The only thing that's important is the hypochlorite percentage listed on the bottle and that the bleach hasn't been on the shelf for a long time. Bleach % hypochlorite will decrease over time so the fresher the bleach, the better. Most bottles will have a date code on the side and you can usually decipher what date the product was manufactured. For instance, on my 12.5% liquid pool shock, there is a number in the printed date code that is "15113" This means that the bleach was produced in 2015 on the 113th day of the year, April 23rd.
    The shock packs may increase CYA levels or they may increase CH levels. Read the label for active ingredients. If the active ingredient contains "dichlor" it will increase your CYA. If the active ingredient is "calcium hypochlorite" it will increase your CH. There are other types of shock such as lithium hypochlorite or non-chlorine shock, monopersulfate. Those two will not increase CYA but are more expensive and therefore, not recommended for regular use.
    Isolated Spa - 345 Gallons
    Jan 2015
    Anthem, AZ
    188
    Re: Clorox Bleach
    Lowes in Dalls/North Dallas carries 10% chlorine. Aldi carries 8.25%, both are cheaper than walmart.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
    Nov 2012
    Dallas, TX
    46
    Re: Clorox Bleach
    Every supermarket in the USA sells bleach. So do dollar generals and CVS or Walgreens. Of course since you are in Texas, there is a Walmart nearby.
    Price is the only nuance.
    Just don't get the stuff with fragrance or easy pour.
    ~21,000 Gallon Kidney Shaped Plaster Pool
    2 feet shallow to 8 ft deep end
    Only one skimmer, and two return jets plus Polaris 280 Jet
    Dallas, TX - West Side of House = HOT
    48 SqFt DE Filter
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Clorox Bleach
    Quote Originally Posted by wil
    I think what he was referring to in this quote was the high concentration liquid chlorine (>= 10%)...and he does have a point. For whatever reason, it is not as easy to find here as it is in other states and this question has often been asked on the forum over the past few years. I've been to pool stores in Florida that carry 12.5% liquid chlorine but the same chain here doesn't carry any at all and they look at you strangely when you ask.
    With that said, Lowe's and Home Depot occasionally carry 10% liquid chlorine, but pay attention to when it was bottled. The higher concentration liquid bleach loses its strength faster than lower concentrations, especially in warmer temperatures. Since Clorox increased the sodium hypochlorite concentration from 6% to 8.25% a couple of years back, this provides a good balance between concentration and shelf-life, plus it's easily available. Since I get it at a warehouse club or grocery store, the product turnover is greater than at Lowe's and HD so there's a much better chance of getting fresh product containing the labeled strength.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Clorox Bleach
    You can use the Hasa Dealer Locator to find their chlorinating liquid in Texas. For example, searching in the Dallas area returns Riviera Pools of Dallas, A-Quality Pool Service in North Richland, and Gohlke Pools in Denton. There's also Napco in Houston where you can buy a carboy/drum or bring your own for refill.
