Results 1 to 10 of 10
Thread: Borax
    Aug 2014
    Shickshinny/PA
    9
    Borax
    I'm getting ready to add borax to our 27 foot above ground pool. We are in the process of switching from bromine to chlorine in the form of bleach. I know I have to add stabilizer, but am unsure of how much. We've never added any. Also, I know I need to add muriatic acid, but I don't have any. I have ph down. Is that acceptable?
    April's Avatar
    Apr 2014
    KY
    138
    Re: Borax
    What test kit are you using?
    Please Post full set of results and we can help better.
    FC
    CC
    CYA
    TA
    PH
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Borax
    Are you doing a complete water exchange in the pool?
    If not, you will not convert from bromine to chlorine. As soon as you add the chlorine it will reactivate the bromine and deactivate the chlorine, thus making it a bromine pool again.
    Support the site
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Re: Borax
    I have read here in the past that simply adding chlorine to a bromine pool only recharges the bromine, it doesnt turn it into a chlorine pool. I think that's why tim5055 asked above, as the water may have to be drained and refilled?
    @titusclan, you will need stabilizer, whether you need acid depends on your pH or total alkalinity, you may or may not need any. if so, muriatic acid is preferable to dry acid, as dry acid adds sulfates to the water
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Aug 2014
    Shickshinny/PA
    9
    Re: Borax
    Since we still have 1/2 a bucket of bromine left, my husband doesn't want it to go to waste. Our automatic chlorinator hasn't been registering any bromine when we have the water tested. We have put bromine tablets into the skimmer basket today just to see if it helps at all. My results are as follows (today testing before adding tablets):
    bromine: 0
    pH: 7.9
    Hardness:310
    Alkalinity: 113
    copper, iron and phosphate: 0
    I added bleach last evening to shock it and the entire pool went green. The pool store told me to shock again using a non-chlorine shock. It's in, but I'm skeptical as to what is going to happen. My husband is angry and wants to get rid of the pool. HELP!!
    April's Avatar
    Apr 2014
    KY
    138
    Re: Borax
    Oh no. Some of the experts will be by to help! I don't know anything about bromine pool.
    This will bump the post up so someone may see it.
    Hope you get it cleared up soon.
    May 2014
    277
    Re: Borax
    Hi, please describe the green water or upload a picture if you can. Is it cloudy green as in algae, or clear green which could be metals in your water, e.g. if you have high iron content in your water
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Borax
    As others have noted, you will not be able to convert your bromine pool into a chlorine pool without replacing the water (assuming it's been a bromine pool for a while so has built up substantial amounts of bromide salt).
    Do you have a blue pool surface? If so, then the color may be yellow which on a blue background will look green. If you add a lot of chlorine that turns bromide into bromine, then it can look yellow until it dissipates. If it's still yellow after a while, then you may have added quite a bit of chlorine so that your bromine level is now quite high.
    The non-chlorine shock is pointless and expensive. It will just create even more bromine (though does so more slowly than chlorine).
    Aug 2014
    Shickshinny/PA
    9
    Re: Borax
    The pool is not cloudy green. We do have a blue vinyl liner also.
    I also should note that we did replace a lot of water this year.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Borax
    So a clear green when you add chlorine can be one of two things. It can be iron or it can be bromine. Since you have a bromine pool, I'm guessing it's bromine, especially if the color dissipates once the water is mixed. If the color were to remain and only drop if the pH drops, then I'd say it's iron.
