Thread: AG liner question...
    coffeegoddss's Avatar
    May 2012
    Minooka, IL
    93
    So after shooing my son out off the deck when I found him playing with the vacuum/skimmer pole by stabbing it into the pool - *facepalm* - it now appears that we have a small hole in our AG pool. Smack in the middle of the floor. We're hoping it's patchable but I've always been a worst-case scenario person and am researching new liners while waiting for my husband to get home and attempt the patch.
    We have unibead j liner now - only five years old. :/ It's a 21ft pool; 54". I'm looking at new liners and everything seems to be coming in 48" or 52". 54" is really hard to find. Did the standard specs change and 54" just not as common anymore? Or is it something with the j liners that I'm not grasping? I would think I need the 54" seeing as that's how high the pool walls are. Why is 52" so much more common?
    AG, 10,400 gallons, filter cartridge, 2HP pump
    Coffeegoddss...bonafide thread killer!
    POOL SCHOOL...fortheloveofgawd, read POOL SCHOOL
    April's Avatar
    Apr 2014
    KY
    138
    Re: AG liner question...
    The patches work pretty good. My liner had 2 holes in it after the installation. I didn't want to deal with draining and refilling so we just patched them. No leaks after 4years and patch is still holding strong.
    No sure about the 54"wall as mine is 52".
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    andyrob2215's Avatar
    May 2014
    Portage, Indiana
    127
    Mine is also 52" and havnt seen many at 54". Are you measuring on the outside of the wall from the base of the wall to the top of the actual wall? Not the top rail. It sounds to me like a patch would work for you though!
    21'x52 AGP 11200 Gal
    TFPC Method
    Feb 2015
    Bardstown KY
    139
    We just bought our pool this year and most of the more expensive ones were 54", mid range were 52", and cheaper pools were 48". Not sure if that is always true or just a local anomaly but 54" is definitely still being made.
    Being that our pool is new I've never replaced a liner, but will it stretch the 2 inches maybe?
    27k gallon 33' round, partially buried 22" Sandman sand filter, 1.5hp 2 speed TidalWave pump, Pentair 'Lil Shark with leaf canister, TF-100 Test Kit
