Thread: Is leslie's instant conditioner cya
    Aug 2014
    NJ
    435
    I went to Leslie's and asked for CYA and they gave me "Instant Conditioner" The one gallon bottle states that it is comprised of 35% monosodium cyanurate monohydrate. An asterik by this number states that this is equivalent to 30% cyanuric
    acid.
    If I am using Pool Math and want to raise my CYA, is this what Pool Math calls "Liquid Stabilizer"
    FYI:
    My test numbers today were: PH 7.4; CL (test from blue box) 1.0-2.0 (not exactly sure); CH 200; TA 120; CYA (between 50-60); FC 1.5; Combined Chloramines .5 I think I need to raise CYA to maintain more Chlorine.
    Thanks
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Re: Is leslie's instant conditioner cya
    If I remember correctly Leslie's carries Natural Chemistry Instant Conditioner. Yes, that is CYA or aka Stabilizer. You have two different types of conditioner/stabilizer. Instant (liquid) is poured into the pool and results in a much quicker rise to CYA levels. Solid (granular) is slowly dissolved over a period of days to raise your CYA. As you would expect the instant conditioner is more expensive than the granular.
    Check the directions on the bottle but if I remember correctly 1 gal per 10,000 gallons of water to raise CYA 32 ppm.
    -25,000 gal. freeform gunite, smooth quartz finish w/ spa
    -2 hp Jandy Pro Series Stealth; Jandy Pro Series Cartridge Filter (CV340)
    -Jandy Pro Series AquaPure Chlorinator; Jandy Pro Series JXi Heater
    -Zodiac MX8 cleaner; Taylor K-2005 DPD Complete Chlorine Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, it is Cya. Liquid stabilizer in pool math.
    Essential Links:
    38,274
    We do not typically suggest the liquid because it is so much more expensive ... should have gone to Walmart
    Aug 2014
    NJ
    435
    Thanks everyone. I'll remember that next time. I was just happy to find someplace that had what I thought I needed.
    Jun 2014
    15,073
    Old (pool store) habits are hard to break. But generally speaking, you'll find anywhere from 25-50% increase in those pool store prices as compared to Wal-Mart or your local grocery store. I generally only go to the "pool store" when I need a specialty part, toy, or as a morale-booster of sorts as I watch others do what I used to before TFP ... spend! $$$$$$$
