Thread: Stuck rubber ball!
    Stuck rubber ball!
    Pool: 600 square feet gunnite pool with attached spa
    In order to drain my pool to prepare for painting/resurfacing, I needed to seal the spa pipes. Since I didn't have the proper plugs, I found 2 round rubber balls (slightly different sizes) to seal the 2 spa pipes.
    It worked great. Pool is now empty as I research masonry finishes.
    When draining was complete, I went to retrieve balls but 1 was missing. It must have been sucked into line at the very end. Do I run the garden hose in the pipe where I inserted the ball, however, I fear pushing it farther? I'm not sure where this pipe leads (either to pool return or back to pumping station. Likely not Skimmer since it is on opposite side of pool.)
    Other posts mentioned Drain King. Is this available at Home Depot/Lowes?
    Information appreciated!!
    30,000 gallons, DE Hayeward Filter, Plaster, In-ground
    WE keep the Chlorinator filled with tabs
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Stuck rubber ball!
    A Drain King would need to be put in from the opposite end to push the ball out.
    The first thing I'd try would be a shop vac on the pipe where you inserted the ball. Might have to apply and release suction several times to jiggle it loose.
