Results 1 to 15 of 15
Thread: Getting Tired
    May 2015
    Goodview, VA
    7
    Getting Tired
    New pool owner this year. Cannot seem to get deep end clear and keep it that way. Only one time (overnight to morning) after finding this forum was I able to get deep end clear but the minute i inserted the Dolphin Triton to sweep it clouded back up and has been that way ever since. I purchased the Lamotte commercial kit with all the bells and whistles (thanks TFP! Now I no longer run back and forth to the dishonest chemical salesman at the pool store!). Here are the results this morning: (added 370 oz bleach 8%, 47 oz muratic acid yesterday evening)
    pH:7.4 down from 7.6 yesterday
    CA Hardness: 220
    CYA: 35 down from 60 yesterday
    ALK: 160
    Free Chlorine: 11 up from 2.4 yesterday
    Residual Chlorine: 11 up from 2.8 yesterday
    Combined Chlorine: 0
    Bromine: 24.75 up from 5.4 yesterday
    Salt: 2900
    Temp: 86
    Sat. Index: + 0.2
    I know that I need Stabilizer. Adding that this morning 6lbs. Wish there was a place to get this other than pool store. Going to try Clorox bran from Walmart unless you advise otherwise. Ran Dolphin overnight and running it now. What else do I need to do to see that quarter on the bottom of deep end. Thanks for what you all are doing here!
    2015 Hayward vinyl pool, 20'x40', 33000 gal?, 3'-8', Aqua Right Goldline control board, T-Cell 15 salt chlorinator, Hayward Max Flo XL 1.5hp pump, 2 main drains and 2 skimmers, LaMotte 7022 FAS-DPD Commercial 7 test kit.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Getting Tired
    Welcome to TFP!!
    Unless you exchanged a lot of water you're CYA did NOT go down from 60 yesterday to 35 today. Can't happen, don't add it.
    I don't know the Lamotte kit, but you won't have chlorine and bromine in the same pool. The Taylor OTO kit uses the same tube/test for both chlorine and Bromine, but it doesn't mean bot are present in the pool.
    You need to go back through the test kit instructions and figure out the testing begfore you add something like CYA that is impossible to get back out of the water.
    Once you are good with the test kit it's time to follow the directions on SLAMing your pool in the How To section of Pool School and follow that procedure completely to the end.
    CC is 0.5 or lower;
    You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    The water is clear.
    When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,040
    Re: Getting Tired
    Welcome!
    Did you replace a bunch of water yesterday? If not, how did the CYA drop from 60 to 35?
    What if CYA really is 60 and you're adding more?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Getting Tired
    Welcome to TFP!
    Have you used a Bromine in the pool previously? If not there isn't a need to show the reading.
    Essential Links:
    May 2015
    Goodview, VA
    7
    Re: Getting Tired
    Never used Bromide and LaMotte told me that because it is a SWG/chlorine pool that there was no need to take that measurement. They also informed me that temperature plays a major part in getting accurate tests. They advise testing water that is 75 deg. They said any higher would give a false lower # esp on CYA and a lower temp would give a false higher #. Going to re-test later this evening. I will repost.
    May 2015
    Goodview, VA
    7
    Re: Getting Tired
    No water added. Will re-test later today.
    May 2015
    Goodview, VA
    7
    Re: Getting Tired
    Re-test results:
    pH: 7.4
    CA hardness: 240
    CYA: 50
    Alk: 80
    FC: 9
    TC: 9.5
    CC: 0.5
    Salt: 2900
    Temp: 75F
    Sat: -0.2
    Ran the dolphin 4x today. Added 7oz of Biogaurd Polysheen Blue tonight that I had left over from all the other chemicals bought at beginning of the year. Guess I'll see in the morning if it has cleared up. Talked to a friend who called his friend at the pool store who said test for phosphates. They don't even test for those at their counter. Thankfully I read the thread here on that. Won't be going down that road!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Getting Tired
    Yep, phosphates don't matter.
    Are you SLAMing your pool? Chlorine is way low if you are. See the Chlorine CYA Chart to see the shock level for your CYA.
    May 2015
    Goodview, VA
    7
    Re: Getting Tired
    Two days ago pool installer came and replaced the sand in the filter. Theory was that there had been so much chemical put in since April 1st that the filter wasn't doing it's job properly. This morning water is clear! Little low on salt and cya but this is the first time we have seen the bottom of deep end this clearly. Here are the #'s this morning.
    pH:7.4
    CA hard:220
    CYA: 60
    ALK: 140
    FC: 5.0
    TC: 5.4
    CC: 0.4
    salt: 2700
    sat: 0.0
    temp: 75
    I did not slam it however due to sand replacement but it looks great. Any input necessary?
    Richard320's Avatar
    Jan 2010
    19,040
    Re: Getting Tired
    Quote Originally Posted by garypritt View Post
    pH:7.4
    CA hard:220
    CYA: 60
    ALK: 140
    FC: 5.0
    TC: 5.4
    CC: 0.4
    salt: 2700
    sat: 0.0
    temp: 75
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Getting Tired
    Your water is a little cold!
    Essential Links:
    DFW, TX
    24,502
    Re: Getting Tired
    Quote Originally Posted by Patrick_B View Post
    Yeah, get that temp above 85 before swimming!
    Salt might be a tad low. But, if SWG is happy we're all happy. Just have a bag of salt around for when the low salt error light comes on.
    May 2015
    Goodview, VA
    7
    Re: Getting Tired
    The water temp in the pool is 88. When I test it I wait about 20 minutes after getting the sample so that the water temp is close to 75. That is the temp that Lamotte says is the temp that gives the most accurate results esp with the CYA.
    DFW, TX
    24,502
    Re: Getting Tired
    Aha! We're just messing around on the water temp cuz all the other numbers look good!
    Aug 2014
    Northern IL
    4,615
    Re: Getting Tired
    Just to put your mind at ease, you can always do an OCLT. You don't have to be at shock level to do it. Here's how: Pool School - Perform the Overnight FC Loss Test (OCLT)
