Thread: Vacuum Port not strong enough
    Jun 2015
    California
    1
    Evening, TFP community.
    My vacuum cleaner (The Phoenix by Hayward) runs at 30% power whenever hooked up to my vacuum port, which didn't occur before. However, when I connect it to my skimmer, the vacuum cleaner performs at 100%.
    I adjusted my regulator for a solution, and the skimmer responds properly, but the vacuum port doesn't. I'd appreciate any suggestions or directional support.
    Thanks for reading,
    Abel
    36000 gallons. In ground. Plaster. Hayward 3020 Cartridge Filter. Pentair 11013 IntelliFlo VS-3050 Variable Speed.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Vacuum Port not strong enough
    Welcome to the forum Abel.
    I often find I've missed something simple in situations like this. Have you made sure there isn't a valve pinched down or something? Perhaps the line is clogged? Even if you get it going, I have to say that a suction cleaner is likely at its limit very quickly in that size of pool. If you've ever thought of going another route, a Robot would be an item to consider for the future.
    Essential Links:
