Thread: SWG timer
    Jun 2015
    Arkadelphia/ AR
    13
    SWG timer
    I am just starting doing the swg. The book says I need to set my 5061 ag pool to 3 hrs and I have the pump for hrs. The filter pump will turn on and off every 4 hrs so with these set this way the SWG and pump should both be on at the same time I believe the SWG will run for 3 hts every 24 hrs please help with info
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SWG timer
    It's difficult to say really. It depends on several factors like how much swimming takes place, how much sun you get, and how much Cya you have to name a few of them. You'll have to monitor the FC levels and see how it goes.
    Essential Links:
    Jul 2014
    Hope Mills, NC
    567
    Re: SWG timer
    Those are just "starting" numbers in the book. The only way to get it dialed in is by using and monitoring.
    Personally, my pump runs 12 hours (8:00am to 8:00pm) and my SWG is set to 20%. That works out to 2 and a half hours of 100% runtime.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
