Thread: Just joined forum
    Jun 2015
    Rocklin Ca
    78
    Just joined forum
    I just joined this forum last week in hopes of learning how to get control of my pool without the help of helpful salesmen. About my pool Iíve had it 10 years itís 20,000 gal in ground. 2013 I had a Pentair Intella flow pump installed, Also bought new filters for a STA Rite 450 sq Ft cartridge filer system. 2014 replaced the pool sweep booster pump with a Hayward 6060. I also have a Aqua Rite Chlorine Generator non functioning for two years debating on replacing it. So all last year my pool has been a struggle to maintain any kind of proper chemical balance. So this year has started off just the same so realizing the local pool supplies are no help, hear I am determined to get control of the pool. Anyway I go by SacDave or just Dave I live in the Sacramento Ca..I just received the TF100 test kit so tomorrow Iíll post some results in Chemistry 201. I have been reading some of the pool school stuff good information. Looking forward to leaning proper pool maintenance Thanks
    April's Avatar
    Apr 2014
    KY
    138
    Re: Just joined forum
    Welcome
    You are going to love TFP and your TF-100 test kit!
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Welcome aboard! Be sure to add the details of your pool to your forum signature. To change your profile and/or signature, select "Settings" (top right under Pool School button). Scroll down (left side) to "My Settings" & select Edit Profile or Edit Signature. It helps immensely when you post test results and ask for advice on how to proceed if we have a better idea of what pool equipment you're working with.
    Isolated Spa - 345 Gallons
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP and for getting a TF-100 right off the bat.
    Jun 2014
    15,004
    New with TF-100 in-hand already. Doesn't get any better than that. Welcome.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
