Results 1 to 7 of 7
Thread: Skimmer Weir Missing - How Can I Identify Skimmer Make and Model
    May 2015
    Moorpark, CA
    171
    Just purchased a new (for me) house. I noticed that the something did not seem right about the way the skimmer was working, and discovered the weir was missing. I can see two pins sticking out where it was attached. I looked for a brand name, but could not find one. What's the best way to identify the make and model, so I can order a new weir?
    Thanks!
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Skimmer Weir Missing - How Can I Identify Skimmer Make and Model
    Usually on the underside of the skimmer cover their will be the brand name and perhaps a part number for the skimmer cover. If you post pictures of the skimmer, someone here will have a good chance at identifying it.
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Here are a whole bunch based on measurements.
    Pool Skimmer Weirs. Skimmer Weir Doors. Skimmer Weir.
    May 2015
    Moorpark, CA
    171
    Quote Originally Posted by JVTrain View Post
    Unfortunately, no brand name found anywhere. Here are some pictures. The middle photo shows two attaching pins, and then above probably a stop.
    Michael
    DFW, TX
    24,497
    Did you look on the underside of that skimmer cover?
    May 2015
    Moorpark, CA
    171
    I looked there, and, unfortunately, there was no writing.
    Michael
    DFW, TX
    24,497
    Dang it! Maybe if you call Sunplay at 877-865-2493 you can give them the measurement and pics and they can help out.
