Results 1 to 18 of 18
Thread: Starting from Swamp
    Jun 2015
    Forest Hill
    20
    Starting from Swamp
    Hello everyone. So, typical story... I bought a house, it came with a pool, I thought. Take off the tarp and find a swamp. The previous owner had closed the pool down 2+ seasons ago, so not really sure.
    To date, I got the pump running (has been running virtually non stop for 4 or 5 days now), added a pH reducer, shock, tri-chlor tablets (that I have since removed), algaecide, and two doses of clarifier. I removed the tri-chlor because they have the stabalizer in them, and our CYA was already pretty high.
    Here are my numbers as of a couple hours ago.
    FC - 7.5
    pH - 7.8
    CYA -Roughly 60
    TA - 110ppm
    CH - 160
    After all this, my pool is way less a swamp, but still not swimmable. There is a lot of foam on the surface, and the water is really cloudy. I was reading up on the SLAM method and was wondering if I should do that, since I have, comparatively, clean water. Any and all advice/tips/recommendations, etc. would be greatly appreciated.
    I also have to say thank you to JVTrain for being the first, and only so far, person to reply on my introduction post on this.
    Forest Hill, MD \ AG 24 FT Round ~ 13,000 Gal \ Hayward Power Flo LX 1.5HP w/ Hayward S210T Pro Series Sand Filter\ Perhaps 2009 \ Taylor Complete High K-2005 Test Kit \ Well filled
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Starting from Swamp
    Well.. it's me again!
    You definitely need to SLAM the pool. Be sure to read through some of the articles in Pool School such as ABCs of Pool Water Chemistry and the links in my signature for the SLAM procedure, CYA/Chlorine chart and familiarize yourself with the Pool Math page and figure out how to use it to calculate your chemical additions. The answer for cloudy, green pools is always more bleach in the proper quantities for your CYA and sticking with it. I'm not sure on your region based on your Forest Hill location, as state added to that would help. If you're in the northern part of the states, you should consider a partial drain to lower CYA to close to 40, then do the SLAM as it will take less bleach/liquid shock. If you're southern states located, maybe take it down to 50 ppm. Wouldn't hurt either way to bring it down to 40 and ease it back up to 50 if you're down south, after the SLAM criteria have been passed. You'd need about a 33% drain, refill to get to 40 ppm CYA.
    If you have questions about Pool Math or anything else, just ask!
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Welcome to TFP!
    It is definitely time to SLAM Your Pool. Drop your PH to 7.2 before you start, the PH test is invalid when FC is above 10ppm.
    Here are some of my fave Pool School articles to get you started with water care.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Jun 2015
    Forest Hill
    20
    Hi folks. Thanks for the replies. To clarify, Forest Hill is in Maryland, just south of the Pennsylvania border.
    After a quick visual inspection this morning, I still have the surface foam. However, I have less cloudiness and the water doesn't seem very green. Then again, the before and after for the chemicals that I have added is significant.
    I just bought 9 gallons of 8.25% sodium hypochlorite bleach to get started. Looking forward to a bright, clean, sparkling pool.
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Hi Vinny and welcome from a fellow Marylander.
    As pooldv said, if you haven't already raised your FC you should lower your pH to 7.2 before slamming. Once the FC is 10 or more you won't be able to accurately measure pH until you're done with SLAM.
    Your signature says you have a K-2005 test kit. Do you have the FAS-DPD test since it doesn't come with the K-2005? Your FC measurement seems like you do but want to be sure since you'll need it at SLAM levels of FC.
    Keep in mind that the shock you added may have also added more CYA that may not show up on a test for a week. You didn't mention what shock you used so just guessing.
    Also, you used algecide and have well water so you may have metals adding to the green.
    Thanks for the pics and keep posting your progress.
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    jjwalker's Avatar
    S. Louisiana
    198
    have you tested your well water to see what your starting point is when adding water? good to know what your adding to your pool
    18x36 vinyl / sport pool 5.5' deep / 1.5hp Tri-Star 2spd / Hayward c3030 325 sqft cartridge / ~15k gal / TF100
    Jun 2015
    Forest Hill
    20
    Thanks guys. We did have metals in our water. My wife went to the pool store, before we started reading on here, and they gave her metal free to use before anything else. We used as instructed, but didnt have the water tested (or test ourselves) for metals again. I dont remember what our well water test showed, but it was good enough to run with a dialysis machine, without any other filtering.
    I am working on refilling the pool after draining some to lower CYA. After I get it back up to the correct level, I will try the CYA, PH and FC testing again.
    Swoopman, our test kit does include the reagents to perform the FAS-DPD test. Here is the Taylor site for the kit. Welcome to Taylor Technologies
    Everything we used, except the Metal Free, was HTH. Shock - Calcium Hypochlorite 56.44%; PH Up - Sodium Carbonate 98%; the Algaecide does not list copper, but being WalMart, I dont expect best quality. We had our chlorinator filled with pucks containing Trichloro-s Triazinertrione - 93.6%, Zinc sulfate monohydrate - 2.9% (available chlorine 84%) I removed these right after doing the CYA test as the tablets contained stabilizers.
    Swoopman, as a fellow Marylander, what would you recommend for a proper CYA? I have been told 40 by JVTrain as a general, as he recommended that prior to knowing I am in MD. Also, what would be the best method to remove the metals, and should I take care of that before or after SLAMing?
    Aug 2014
    Seminole, FL
    92
    The K-2005 does not contain the FAS-DPD, just the DPD. The K-2006 has the FAS-DPD. Have a look at this link ...
    http://www.troublefreepool.com/conte...its-comparison
    Mike
    Built 1980, 19' x 30' almost rectangular, screened 15,000 gal, plaster, Hayward DE 3620 filter (currently using cellulose), Emerson 1081 1HP pump, AquaCal Heatwave SuperQuiet SQ110R heater, Zodiac T5 Cleaner, Taylor K-2006 test kit
    Jun 2015
    Forest Hill
    20
    To get the FAS-DPD test, I just need to add the Taylor R-0870 DPD Powder and the R-0871 FAS-DPD Titrating reagents, correct?
    Amazon.com : Taylor Replacement Reagent FAS-DPD Refill Kit (Large) - Over 100 Tests : Patio, Lawn Garden
    Aug 2014
    Seminole, FL
    92
    Yup, or this one ...
    http://tftestkits.net/XL-Option-p62.html
    I personally would go with this as the reagents are likely to be fresher.
    Jun 2015
    Forest Hill
    20
    Just submitted my order to TFTestkits. Thanks for the link.
    If you dont mind my asking, what is the difference between the two types of Chlorine testing? I didnt find that in Pool School, or I missed/ dont remember it
    Apr 2013
    North OKC Area
    300
    I don't use clarifier or metal reducing stuff... Did anything you added say to set the filter to recirculate for a while, then turn off pump to allow to settle and then to vacuum to waste? If so, you need to allow things to settle and vacuum to waste. If you ran the pump on "filter" or "backwash" mode with any product that has those instructions before vacuuming to waste, you might need to deep clean your sand filter.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Quote Originally Posted by VinnyC View Post
    This is my first full season with TFP. Right now my CYA measures between 30 and 40 so I've been using 40 to figure FC amounts. The pool does not get full sun all day but does get a fair amount. I loose about 2ppm to 2.5 ppm FC a day when no one's swimming but I do have a lot of organic debris too - leaves, flower petals, slugs and such. I'm happy with where the CYA is now.
    Hope that helps.
    TF-100 Test Kit
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    The FAS-DPD is a titrating test - it is more accurate and can measure to high FC levels needed for SLAM.
    TF-100 Test Kit
    Jun 2015
    Forest Hill
    20
    Awesome! Thanks everyone.
    DanielP, nothing that I used required recirc then settle. It was all run pump at least one hour after adding.
    After draining (great time to backwash) and refilling to reset CYA, new results are below.
    CYA - 44-45
    PH - 7.1
    FC - 1
    TC - 10
    Since the numbers are all in range to start SLAMing, I will start tonight. I was worried about needing the FAS-DPD test to start, but with the info from Swoopman, I feel that the low number should be alright with my current test. I will use my FAS-DPD when it arrives in a day or two.
    In the mean time, I will keep everyone posted and have pictures when there are noticeable differences.
    Jun 2015
    Forest Hill
    20
    Quote Originally Posted by swoopman View Post
    Of course, in my excitement, it wasnt until after adding 3 gallons of bleach that I realized I cant measure up to the 20 FC I need to maintain. Guess I will have to use tonight as a pre-SLAM. Lesson learned. Bummer
    Apr 2013
    North OKC Area
    300
    Try to take pictures of the steps if they are installed, it helps notice the difference in clarity.
    Adding DE to your filter will help you make the water clear faster but you will need to watch the psi and backwash sooner. You should backwash when your pressure rises 25% over your clean pressure (psi right after a backwash and rinse).
    Jun 2015
    Forest Hill
    20
    Alright. So I got the new vacuum and brush the in. Still waiting on the FAS-DPD kit. Either way, went to vacuum and find my skimmer needs to be replaced. Oh, how I am loving this pool.
    Anyone have experience with this? I am thinking I would like to convert to a wide mouth skimmer.
