Thread: SLAM Process
    Jun 2015
    Pittsburgh, PA
    27
    SLAM Process
    Can someone tell me (or direct me to a link) that spells out the SLAM process in detail? I should be receiving my TF-100 on Monday, so I'll probably be starting my SLAM shortly thereafter. Went out and purchased 6 jugs of 8.25% bleach to start. How many jugs should this process generally take? My pool's water does look fairly clear, though still a good bit of debris I need to remove.
    -Jon
    24' Round AGP, 4' deep, vinyl siding. 13,500 Gallons. Hayward Perflex DE Filter (EC40C75). Hayward Power-Flo Matrix Pump. TF-100 Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: SLAM Process
    There's no set rule for how much bleach a pool will take. It all depends on how far gone (green, cloudy, leafy, wild life infested, etc.) the pool has gotten, how well the filtration system is working and the diligence of the person performing the testing, brushing/cleaning and chemical additions. I'd say 6 gallons will get you started, but it may take many more than that.
    The SLAM procedure can be found in Pool School -> How To -> SLAM - Shock Level And Maintain... or a shortcut is the link in my signature.
    Isolated Spa - 345 Gallons
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: SLAM Process
    Keep in mind that the M in SLAM is the most important part of the process. Maintaining chlorine levels as close as you can to the target for your CYA throughout the SLAM is critical.
    Feb 2014
    Central Minnesota
    5,080
    Re: SLAM Process
    Quote Originally Posted by BoDarville View Post
    So true! Can we start calling it SLAMaintaining? Doesn't exactly roll off the tongue...
