Thread: Index pump suction
    Jun 2015
    Oconomowoc
    1
    Index pump suction
    I have an Intex easy set pool 18x48 with the Krystal Clear model 635t dual suction filter pump, shouldn't I be feeling the section of the pump? There's water going through it, just wondering if I did something wrong or is it just not that good of a pump?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    Re: Index pump suction
    Have you checked the cartridge to see if it's all gunked up? A good rinsing or a new cartridge might help.
    But yes, for your pool, that pump is none too big. Is the same pump that came with my 16'.
    This would be a good upgrade for you: Walmart: INTEX Krystal Clear 2800 GPH Above Ground Swimming Pool Sand Filter Pump 28647EG
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
