Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Tf 100 first test
    Apr 2013
    Argyle, TX
    77
    Tf 100 first test
    Hi
    Just had my pool for a little over a week now and the test kit just arrived today and I want to post up the initial readings.
    PH-7.5
    CL-5
    CC-5.5
    T/A-420
    CYA-38
    I have been adding 8.25 % Bleach to try to keep the chlorine up and so far used 1.5 gallons over 7 days
    I had 1.5 gallons of MA from last year that I added Saturday
    Also bought 4 LBS of CYA powder yesterday and added a little more than half.
    This is my first ever venture into testing and I read the directions as I went through and also viewed the TF videos just before going out.
    OK what is next?
    21' NEW YORKER II 54" DEEP AGP Private Label MORADA RTR WILBAR Aluminum wall
    Hard Bottom and 1/4" Floor Pad 1/8" Wall Foam Well Water Perma 2500 Unibead liner King Technology Pool Chlorine Feeder HAYWARD Diver Dave cleaner
    Waterway 22″ Sand Filter 1.5 HP Center Discharge Pump Single speed Wide Mouth skimmer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Tf 100 first test
    I'd review the videos again. CC shouldn't be 5.5. If it is, you have problems.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Welcome to taking over your own pool.
    I'm assuming acid is to reduce the TA number? That number is suspect.
    Your CYA is in range for a vinyl chlorine pool and you want to be careful not to overdo that as the only way to correct high CYA is to drain water.
    Could you describe how you did the TA test? And how does the water look?
    Edit......Richard beat me to it again. And I totally missed the 5.5 on CC. I was spinning my head over that TA number.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    30,432
    My bet is you meant CC .5 ppm and the TC was 5.5 ppm. That said, your TA is wa-a-a-y up there and could be a testing error did you read the directions on wiping the dropper tip when your kit is new?
    You are about to go swimming, I think. I assume your water is very clear and you will keep you FC up at the level indicated in the CYA/FC chart. You should be good to go.
    Work on those tests again when you have time.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    I will assume the pH and CL results you got were from the OTO red/yellow drop test (in the blue case).
    The CC you got was actually the FC (you added powder to the tube and added 11 drops for it to go clear).
    As to the CYA test, there is no way to get 38. Don't equate “just a little any marked number” to a specific number, the tube is not marked for such extrapolation. Use the next higher marked number.
    Support the site
    Jun 2014
    15,253
    When it comes to chlorine, you should've had to do the FC test first (scoop of powder that turns water pink). You then add the R-0871 drops until it turns clear, counting the drops. Example: 14 drops to turn clear x .5 = FC of 7.
    Next is the Combined Chlorine test. You immediately add 5 drops of the R003 reagent to that same sample. If it turns pink, you count the number of R-0871 drops until that turns clear: Example: 4 drops to turn clear x .5 = CC of 2.
    Not sure what happened with your TA test. It should be somewhere around 80-120 give or take. You might want to double-check that process.
    Jan 2015
    Anthem, AZ
    188
    Just to let you know, thats awesome results from a first time TFPC. You should see mine and every other new person here. Good luck!
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
    Apr 2013
    Argyle, TX
    77
    I just re tested a few tests
    FC 4
    CC 1
    T/A 450
    wipe tip for each of 45 drops
    Jun 2014
    15,253
    The FC and CC look more realistic and not bad. Let's talk about TA directions:
    You filled the larger vile up to 25 ml with pool water; then added 2 drops of R-0007; then 5 drops of R-0008. Now the water sample "should" be green. Now you start doing the drops of R-0009 until it turns red. Once you get the sample to turn red (i.e. 10 drops), you multiply it by 10. So in this case 10 x 10 = 100.
    Are you saying it actually took 45 drops to turn from green to red?
    Please see this thread: just got tf-100 test kit and not registering alkalinity
    It's possible your TA and PH are much lower than expected. Let us know if your colors did this as in the example.
    Apr 2013
    Argyle, TX
    77
    I did exactly what the card said
    Sample turned green and took 45 drops to turn pink and I wiped after each drop with a clean damp microfiber cloth.
    We have Well water
    It is clear to the bottom
    Last night the walls and floor felt very slick compared to before
    Jun 2014
    15,253
    Did you get a chance to read the link I provided? I'm wondering if your situation of color changes during the TA test matched what happened there. It might explain what is happening to you.
    Apr 2013
    Argyle, TX
    77
    I read the link and did the test just as described by the instructions
    I may take a sample to Leslie to verify
    Jun 2014
    15,253
    Okay. I was wondering (hoping) that perhaps your TA and/or PH are so far off (low) that it made your colors change differently than what is expected on the instructions. That happens sometimes. It happened to me once before as well. Well, let us know what you find out then.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    I am going to watch this one to learn about crazy TA numbers. I am interested to see what happens.
    Kim
    Apr 2013
    Argyle, TX
    77
    OK
    The Wife took a sample to Leslie's by our house and got the test done and the Manager was there and I have talked with him several times and bought a vacuum head and other small hardware items and he is zero pressure very laid back and older so I trust him a little.
    FAC 0
    TAC 0
    Salt 600
    CH 60
    CYA 50
    TA 300
    PH 8.5
    Acid Demand 4
    Copper 0
    Iron 0
    Phosphates 0
    They recommend adding 1 pound 7 ounces Dry Acid or 18 Fluid ounces of MA
    It goes on to say "your pool may require the addition of an extra 33#s dry or 18 Quarts liquid acid to lower Alkalinity"
    I am not following this advice just reporting what was recommended
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Slick walls is a sign that algae is growing in your pool. Keep that chlorine level up above the minimum level for your CYA level to keep the pool sanitized and algae free. Use this Chlorine CYA Chart to set your chlorine level.
    If you want you can test your fill water to validate your TA level. Might take another 45 drops of reagent. That is a high TA level. High TA usually causes PH to rise. So be sure to test Ph every few days, when it hits 7.8 add muriatic acid to drop it to 7.2, use Pool School - PoolMath to calculate how much to add. Doing this repeatedly will lower your TA slowly. If you get tired of adding acid every few days then you can more actively lower you TA as follows, Pool School - Lower Total Alkalinity, but it is still a fairly slow process.
    Apr 2013
    Argyle, TX
    77
    This morning while waiting on the coffee to brew I tested the tap water right from the kitchen faucet.
    Thoroughly rinsed the cylinder and filled to 25ml then added 51 drops wiping with damp towel and swirling generously between drops the water finally turned pink.
    Each drop left a hint of color change as it hit the sample and mixed in.
    TA 510
    My initial tests were done after there were some chemicals already in the pool and that was 420/450
    Jul 2012
    Tallahassee, FL
    30,638
    WOW! Your tap water has a TA of 510? WOW! I wonder how that happens and what it means? Is it well water of city water?
    Well at least you know and can get it down in the pool.
    Kim
    Jun 2014
    15,253
    I don't recall ever hearing that myself. You might also want to call your water source and ask them if they have any such data. My local water company provided an annual report to disclose all the levels of our water.
  20. Back To Top    #20
    Apr 2013
    Argyle, TX
    77
    What is the best method to aerate a above ground pool?
    I can access a small blower and make a PVC pipe with lots of holes to place in the water
