Thread: Newbie with test results on new pool. TA very high
    Jun 2015
    Florida
    2
    These are the test results from our new pool. Finished filling yesterday. Pumps running but swg is not on yet. TA is really high wondering what I can do about that. Water clarity is not bad. Wondering when I should add the salt and turn on the swg?
    FC- .6
    CC- .10
    PH- 7.8
    TA- 275
    CH- 175
    CYA- 30
    Taylor k2006 test kit
    22 x 52 intex ultra frame
    intex sand filter and swg
    Hayward thru wall skimmer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Newbie with test results on new pool. TA very high
    Quote Originally Posted by MartyMart View Post
    FC- .6
    CC- .10
    PH- 7.8
    TA- 275
    CH- 175
    CYA- 30
    Hmmmm. check the decimal places on those chlorine readings. The Taylor kit isn't that accurate.
    Secondly, repeat that TA test but wipe the tip of the bottle off with a damp paper towel before testing and between each drop. Static electricity on new bottles is a known problem, and will make the drops too small, hence more, hence falsely high TA.
    Once you have the TA reading, plug numbers into poolmath and lower pH to 7.2 with acid. Give that half an hour and raise the FC to 5 or 6, if it isn't already.
    Salt can go in anytime. You'll want higher CYA if you're going to use the SWG, too. Has yours all dissolved yet> What did you target? I suggest holding Diamond Day if there are any children in the household.
