Results 1 to 9 of 9
Thread: Algae
    Jun 2015
    Wright city mo
    5
    Algae
    Is it possible to have algae with a .5 ppm loss on OCLT and no cc's. I have patches of green on the sides of pool.
    38,415
    Re: Algae
    Welcome to TFP!!!
    It is possible. If you see algae, you need to follow the ShockLevelAndMAINTAIN Process.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Algae
    Welcome to TFP!
    Yes, it happened to me last Saturday. Water was/is crystal clear and CC was 0. The reason it happened to me is because my chlorine level dropped to 1.5ppm due to high swim load and lack of testing on my part. It is important to keep the chlorine level above the minimum level for your CYA level at ALL times. Chlorine CYA Chart
    Jun 2015
    Wright city mo
    5
    Re: Algae
    I think thats what happened,I put a puck floater in pool while on vacation.I started slaming last night.
    AG 18x33 vinyl JW titan, 15500 gal. AO smith 2 speed pump. waterway FC100 cartridge filter.Raypak 8350 Heat pump.
    Jun 2015
    Wright city mo
    5
    Re: Algae
    Thanks for the help. pooldv did you SLAM your pool? How long did process take?
    38,415
    Re: Algae
    The SLAM process takes as long as it takes ... could be a few days, could be a few weeks. Depends on what is in the water and how diligent you are.
    DFW, TX
    24,502
    Re: Algae
    Cleaned mine up in 2 days. I brushed the pool about 4 times each day and brushed the algae spots about 30 times per day. Also took the light out beginning of day one and cleaned that out. Brushed a little more on day 3 but there was nothing to brush.
    It was really terrible to have hang out in the pool all day for 2 days in the sun with tasty beverages! But, I do whatever it takes to keep my TFP clean!
    Pool is absolutely spotless, I could not find a speck of algae last night. And I am still keeping chlorine at about 20 just to be on the safe side. CYA is 70. If it is still spotless tonight I might start letting it drop.
    Jun 2015
    Wright city mo
    5
    Re: Algae
    That does sound terrible!! Unfortunately it's raining cats and dogs and I keep having to lower the water level. I just finished vacuuming and brushing walls in the rain. Going to add more chlorine. Glad to hear your pool is looking good.
    Jun 2015
    Wright city mo
    5
    Re: Algae
