Thread: Mineral Springs Box shows 0 cell current
    Jun 2015
    Sparrows Point/Maryland
    1
    What is wrong when the Mineral Springs diagnostic setting reads 0 Cell Current? Is the cell bad or is the board bad? Voltage reading is okay. Cell was last cleaned 2 months ago. Mineral readings are 500 ppm lower than pool stores.
    18,000 gallons in-ground plaster
    mineral springs system
    DE filter
    Jun 2011
    Long Beach, CA
    2,778
    Re: Mineral Springs Box shows 0 cell current
    Welcome to TFP!
    There could be a few different things causing the 0 cell current. Post all the diagnostic numbers as you go through them. A salt reading that is 500ppm less than pool stores is within the tolerance of most salt tests. Does your pool store have a tester to see if the cell is working?
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    You know it cycles off and on. You need to test your salt independent of the pool store and the SWG.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
