Thread: Ordering our 1st pool
    Jun 2015
    Kalona,IA
    1
    We have the option for 1 or 2 skimmers and returns.
    What do you think? Is more better?
    Radiant Pool, Garnet design, IG, vinyl liner, 18 x 36, 19,000 gal., Pentair TAG 60 sand filter, Pentair 1.5 HP Pump, Pentair 90 Heat pump.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Re: Ordering our 1st pool
    I suspect it depends on your site specifically, but as someone with a lot of trees, a terrace, and windborn organics, I'd have loved a second skimmer in my pool
    At the same time, I dramatically reduced the amount of debris by installing a cheap pool skim product on a return that creates a Venturi effect and collects debris on the south end, so even if you go with one now and later wish you had a "second collector" there are inexpensive options
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Agree with SW. If you have lots of trees or the wind blows a lot from one direction and then switches to another direction then it is great to have two skimmers. For us we get a lot of wind from the southwest and a lot of wind from the northwest depending whether we are getting a warm front or cool front. It would be good to have a skimmer downwind for each direction.
