Thread: Pool pipe plumbing mismatch ????
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    My pool has 2 inch coming from the skimmer and the two main drains and 1 1/2 inch going on the Jets is that normal????? The pools was at the home before I moved in .. So is this normal practice. I'm thinking to switching over to a VS pump Ecostar. What should I use 2 inch or 1 1/2 for the filters and the return or leave it at alone ....
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    Jan 2015
    Tempe, AZ
    15
    Re: Pool pipe plumbing mismatch ????
    Well that is how mine is, I have 2 1/2 from the drain/skimmer and 1 1/2 from the dedicated vacuum port, and the return loop is all 1 1/2. I just recently re-plumbed my pad when i installed a new pump and filter, and asked a similar question on if I could use 2" or not. The answer was use the 2". On the equipment I purchased, it was all 2" ports so it was easier to not have to re-size everything at each port.
    40,000 Gallons- "Lazy L"; IG-Fiberglass; Pentair Clean and Clear+ 520; Circupool VJ3 VS Pump (2.4 SFHP); Circupool SJ-45 SWG
