Thread: Pool Safety Cover and Pavers
    Jun 2010
    Massachusetts
    96
    Still waiting on that permit, but while we are waiting I am thinking of all the questions I have about this new build. Our last pool had stamped concrete, so the safety cover was installed by putting anchors into the concrete (and some longer achors in the grass on the back side). This time we are thinking pavers, so I am wondering if the install is the same. Do the anchors get drilled into the beautiful pavers after they are laid, or is the cover measured and incorporated into the decking plan.
    We've met with two decking folks recommended by our builder. The first does everything, including concrete and pavers. The second is a landscaper who does pavers. My concern with doing concrete again is mostly how hot and slippery it got. Pavers worry me because they always seem to grow weeds. However, having seen some very nice paver jobs I think we are leaning in that direction. We will likely do the Techo Blue 60 with a combined color. I can't remember who, but someone here has pictures of their job in northern Mass or NH with that blend and it is lovely.
    As much as I promised myself I would relax and not get caught up in the timeline this time, it is just too exciting not to. Hoping the permit comes in this week and we can start digging next week. Maybe we'll get a few weeks of swimming in before the end of the season!
    Building 20x40 free-form pool; pebble sheen, caretaker in floor, swg, intelliflo pump, heater. Sundance 800 spa happily in use. More to come!
    May 2015
    Barrie/Ontario
    19
    Re: Pool Safety Cover and Pavers
    If you are putting in a liner pool like I did, my pool perimeter is 24" out from the pool and then I am going with pavers. The one quote I got back regarding the safety cover is that they supply short springs and you drill into the perimeter cement. They also had short paver anchors and long soil anchors. You should be covered. If your pavers are larger, drilling with a proper bit and water for cooling should keep them from cracking. You can also use the polymeric sand for the pavers that you wet and it bonds to the paves and seals the deck. Weed control
    Brent H
    Inground 36000 gal, T-15 Salt system, 1.8 HP VS pump, 425 cartridge filter
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Our polymeric sand in our patio (not near our pool mind you) has lasted well for five years. But a few weeds are starting to poke through. I'm going to rent a plate compactor and refill it this fall. I was pleased with the longevity. I've heard that polymeric sand may lose its bonding capacity (and thus wash away) more quickly when it is subjected to repeated wet and dry cycles as it would be near a pool. Not a deal breaker by any means though and may not even be reality.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Dec 2009
    Central Massachusetts
    2,690
    For safety cover installation in pavers, your drill at a joint, not through the center. For the anchors, you use 20" pipe that gets driven into the ground through the drilled holes. The cover anchor gets put into the top of the pipe. I had 5 plus feet of snow on mine this last winter and had nothing move, so it's fine for heavy loads.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    May 2015
    Barrie/Ontario
    19
    Good to know - so they use the ground pegs into the paver gap .....nice
    Brent H
    Jul 2014
    New England - MA
    310
    Quote Originally Posted by bk406 View Post
    Great information. We're also finalizing our material selections. Our final 2 contenders are Techo Bloc Blu 60 or the Aberdeen. Will make a decision in the next day or 2.
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
