Thread: Pentair IntellipH Questions
    tucsontico's Avatar
    Mar 2014
    202
    I installed a Pentair IntellipH system (part # 521377) about 18 months ago. It has been working great and, because of the outstanding advice on this website, I bought a replacement pump head (Pentair part # 521514). This year, while doing my "spring cleaning" of the pool, I noted the original pump head was badly corroded so installed the replacement unit. All appears to be fine but, when I went to order another replacement pump head online, several retailers stated that the item was "discontinued by the manufacturer."
    I checked the Pentair website and the owners manual for the "new" IntellipH (after 8/2014) definitely shows a different pump head. From the photos in the owners manual it appears that it should be a direct replacement for the older-style unit. Does anyone know if the "new" pump head design will fit the older IntellipH canisters? I've tried contacting Pentair (both via email and phone) but have gotten no response.
    Thanks for your help!
    19,500 gal, 16' x 38' PebbleTec IG Pool, Built 4/2013; Pentair IntelliFlo VS 3050 3 HP Pump, Pentair Intellichlor IC40 SWG, Pentair IntellipH, Pentair 520 sq ft/150 GPM Cartridge Filter, A&A In-Floor Cleaner, Dolphin Nautilus Plus Robot (aka "Robbie"), Pentair EasyTouch Power Panel w/ Quick Touch 4 Remote Control, Autelis WiFi controller, Clear 12 mil Solar Cover on Presto SS Reel, Taylor K-2006 Test Kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Pentair IntellipH Questions
    Hi, I don't know the answer and I'm surprised you didn't have better luck with Pentair, they are usually pretty responsive.
    I bet these guys know the answer and they are even more responsive. ,
    Pentair IntellipH Pumphead 521514
    tucsontico's Avatar
    Mar 2014
    202
    Quote Originally Posted by pooldv View Post
    Thanks for the link. The photo on the linked webpage is the "old" Pentair pump head. The new version is shown in this owners manual on pages 10-11: http://www.pentairpool.com/pdfs/intellpHOM.pdf. I will try to contact Sunplay to see if they have an answer. Thanks again.
    Dec 2013
    San Diego, CA
    18
    Tucsontico, were you able to find the part number for the "new" pump head? I ordered p/n 521514 from Sunplay and got the old Shurflo pump which does not fit my Intelliph.
    21,000 ga plaster pool with infinity edge.
    Pentair Easy Touch controller, IntelliChlor, IntellipH.
    Pentair 3hp VS pool pump, Pentair 1.5hp single speed pump for infinity edge.
    Rooftop solar.
    Dec 2013
    San Diego, CA
    18
    I called Penair. Intelliph models built after 2014 require you to replace both the pump head AND motor as one assembly. The p/n is 521515. The cost is around $125 compared to $35 for the old style pump head w/o the motor. Ouch! Moral of the story, regularly replace the stenner tube before it breaks and the pump head will last much longer.
    Rooftop solar.
