Thread: Diving board replacment and saftey cover options....
    May 2012
    Henderson, TN
    234
    My first question is we are kinda wanting a springier diving board for our pool. We currently have a U-frame setup and I was wondering what was the best option for a springier board?
    My second question is I usually don't have a lot of help installing and removing my safety cover. Does anyone use some kind of roll up system or have any good ideas for installing the cover by myself?
    35000 gallons
    Hayward Sand Filter
    Jandy AquaSeries Ei Pure Salt System
    IG
    Pentair Superflow 1hp
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Diving board replacment and saftey cover options....
    I have tried to do the safety cover myself but it's just much easier with two people. If you fan fold the safety cover when removing, it's easier to install again. You could try to roll it on a solar cover reel if you have one and unroll it off the reel, but I suspect that would be too much weight for most reel systems, especially if your pool is 20 feet wide.
    I'm not much help on diving boards as I've always had my old rusty but functional board since I moved in. I know they seem expensive for what your getting. Think my neighbors new basic diving board like mine was close to $2000 installed.
    Isolated Spa - 345 Gallons
    May 2012
    Henderson, TN
    234
    Quote Originally Posted by JVTrain View Post
    I normally fold it up to make it easier to install. It's just so heavy, but you know what I mean. When I uncover the pool, I generally drag it out to the yard and lay it out flat so I can clean it really good, then fold.
    As far as the diving board, I am just really looking for the a board itself that will simply bolt to my my u-frame setup that is already there. We have a basic board that I feel is fine but my son wants something springier.
    35000 gallons
    Hayward Sand Filter
    IG
