Results 1 to 8 of 8
Thread: Summer Pool Temp in Vegas??
    I am curious as to other Vegas or extreme heat cities as to what they maintain their pool temp to be in the summer?
    Last summer was my first and I think I did good with Bleach, but I have a feeling the high temp during the day of the water was causing some serious chemical usage.
    I have a solar panel and just let it maintain the temp all summer, I think I had it set to 85-87, but I know somedays the water temp was up to 92-93. Remember the average daily temp was around 108-110.
    Any suggestions?
    12,000 Gallon
    Hayward 2HP Pump
    Solar Panel
    TF-100 Kit
    Built 2004, bought Dec 2007
    BBB All the Way
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Summer Pool Temp in Vegas??
    Though not in an extreme climate, we keep our pool at around 88F and it varies in the summer from 86-90F but does not seem to have unusually high chlorine usage. If the pool is unused, then the chlorine usage is around 0.6 ppm per day with around 3-4 ppm FC and 30-40 ppm CYA. However, I have an opaque pool cover that keeps out the sunlight. When the pool is used every day and the pool is open for 1-2 hours, then the usage climbs to around 1 ppm FC per day.
    So I suspect that any unusual chlorine usage you are seeing is mostly due to breakdown of chlorine from sunlight. A higher CYA level, with correspondingly higher FC level, can help. If your FC/CYA ratio is on the edge, then you could be seeing chlorine demand from nascent algae growth.
    Richard
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    You could invest in an Aquacal Icebreaker and cool your water during the summer.
    30,426
    Cool your pool thru evaporation. You'll see less chlorine usage and enjoy your pool much more.
    best-way-to-cool-down-pool-temp-t6515.html?hilit=evaporation
    So I should not run the solar at all during the day?
    The pool temps changed dramatically overnight, so in the morning temp would be upper 70's low 80s, solar panel runs when the pump runs if the water is not within 2 degrees of desired temp which was about 87. Thats what happens most days.
    My main question is how warm do others keep their water? sounds like 85-88 is not unreasonable but 90's is too much.
    The issue last year was balancing. I tried raising CYA to 60 or 70 to compensate but them somehow still had 5ppm usage per day, shocked probably 6 or 7 times throughout the summer even though I was maintaining chlorine levels its like I would maintain them then all of a sudden i would go from 3-4 usage per day up to 7 within a couple days, so I would check CYA and CYA would be 40. Just seemed impossible to maintain and instead of 5 minutes per day it was 15-20 plus hundreds of trips to buy chlorine. I NEVER saw anything in the water that looks like algae so I always assumed some sort of organics but seemed like I was shocking for 5-6 days every other week. Soooo.... I was wondering is lowering my daily water temp slightly would help the chlorine usage.
    12,000 Gallon
    Hayward 2HP Pump
    Solar Panel
    TF-100 Kit
    BBB All the Way
    Jun 2008
    Marana, AZ
    347
    It was probably the direct sun more than the relatively high temperature of your water. I noticed a big drop in chlorine usage when my hubby put a shade made from a large tarp over my pool! It also made the water a little cooler. One thing that I did was instead of using household bleach I would use the liquid chlorine from the pool stores. 10% chlorine - so I wasn't using as much.
    Raising my CYA to 50 helped some, too. I did use tri-chlor tablets for a little while, to go from 40 to 50.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    We keep our pool around 83. The more active you expect to be the lower the ideal temperature is. If you are swimming laps then temperatures in the high 70s are often good. If you are lounging around then temperatures in the high 80s can be nice.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Our pool pretty much stays in the 87*-91 range,88-89 being ideal. Up here in WI we run solar heat all day to keep it there though. We pretty much don't go in, except the dog, if it's less than 86*. Our pool's not really deep enough to do much other then lounge, so the warm water is nice. We'll see how it ends up this summer though. Now we've got a hot tub which will be heated exclusively by solar(hopefully). This will take some of the heat the pool normally gets, but we'll see what happens.
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
