Results 1 to 10 of 10
Thread: Low to no pressure
    Jun 2015
    Palm Beach Gardens
    16
    Low to no pressure
    Hi, I am new on this site, and new to owning a pool. We bought a crack house, and we've been fixing it up. The pool is only 3,000 gallons, and it was a viscous pond of scum. We fully drained it with a sump pump and had the pump, filter, and valves replaced.
    The he pool has 7 returns, a waterfall, and a fountain. I do not feel any water coming out of any returns, I do not feel any suction from the skimmer or from either floor drain, and the fountain is a mere trickle. It seemed fine for the first day or two after the new equipment was installed. Any ideas why I have ridiculously low pressure?
    i am frustrated. Thanks.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    Re: Low to no pressure
    3,000 gallons and 7 returns, waterfall, and fountain? You sure about the gallons? Did you drop a zero? Welcome to the forum.
    38,528
    Welcome to TFP!!!
    Either it is 30k gallon pool ... or a 3k "spool" spa/pool
    Please add your pool details to your signature as described HERE as it will help us help you.
    What is the filter pressure doing when you see the flow rate drop?
    Jun 2015
    Palm Beach Gardens
    16
    Yes, it is tiny. 2 returns and a fountain on the sun shelf. 3 returns on the seat off of the sun shelf. 2 returns in the "deep" end.
    Jun 2015
    Palm Beach Gardens
    16
    Thank you both for welcoming me. The filter pressure is around 5psi.
    38,528
    What does the water look like?
    Jun 2015
    Palm Beach Gardens
    16
    Is that enough info in the signature? Why can't I add a pic?
    3,000 gallon pool, IG, marcite finish, new equipment: Hayward 100 sq ft cartridge filter, 1.5 hp Hayward SP2602VSP variable pump, Hayward swimpure plus salt chlorination, valves. not sure when it was built, ware tested at pool store
    38,528
    Now we see that you have a VS pump. What model is that? (add to Sig) What speed are you running it at?
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    FYI, we do not trust pool store testing and I highly recommend you invest in one of the Recommended Test Kits before you have a chemistry problem.
    Jun 2015
    Palm Beach Gardens
    16
    Jun 2015
    Palm Beach Gardens
    16
    The water is currently clear due to all the chemicals they had me add.
    Why test it myself? Are they over-selling me chemicals?
    i added the model to my signature. It maxes out at 3,000rpm. I've not touched the default of:
    V1: 1500 8 hrs
    V2: 2400 4 hrs
    V3: 3000 1 hr
