Thread: Plastic leg caps
    Jun 2015
    Glenwood, MN
    1
    Plastic leg caps
    I am wondering if anyone has a good idea for a replacement to the plastic leg caps on a metal support above ground pool. I have two or three that have broken and am placing my pool on a brand new cement pad. I do not want to pay 4-8 dollars for a silly piece of plastic, which is the rate they are being sold on Amazon and Ebay. Any ideas would be appreciated. Thanks~Brandy
    24' x 52" Intex Ultra Frame above ground pool
    Sand Filter Pump
    Minnesota
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Plastic leg caps
    Measure the diameter of the pipe and see if there's something at the hardware store that will fit. Lowes
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    If you could post a picture of the cap with a few approximate dimensions, we may be able to make a connection to something inexpensive, that could be a suitable substitute.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
